Datasheet Texas Instruments BQ24052 — Даташит
СерияBQ24052
Зарядное устройство для одноэлементного литий-ионного аккумулятора, 1 А, с автоматическим определением переменного тока/USB, Rntc=100 кОм
bq2405x 1-A, Single-Cell Li-Ion and Li-Pol Battery Charger With Automatic Adaptor and USB Detection datasheet
PDF, 2.2 Мб, Версия: C, Файл опубликован: 11 дек 2014
BQ24052DSQRBQ24052DSQT
Доступность образцов у производителяДаНет
N12
Pin1010
Package TypeDSQDSQ
Industry STD TermWSONWSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY3000250
CarrierLARGE T&RSMALL T&R
МаркировкаCGTCGT
Width (мм)22
Length (мм)22
Thickness (мм).75.75
Pitch (мм).4.4
Max Height (мм).8.8
Parameters / ModelsBQ24052DSQR
BQ24052DSQR
BQ24052DSQT
BQ24052DSQT
Absolute Vin (safety rating)(Max)(, В3030
Battery Charge Voltage(Max), В4.24.2
Battery Charge Voltage(Min), В4.24.2
Cell ChemistryLi-Ion/Li-PolymerLi-Ion/Li-Polymer
Charge Current(Max), A11
Control InterfaceStandalone (RC-Settable)Standalone (RC-Settable)
Control TopologyLinearLinear
Number of Series Cells11
Operating Vin(Max), В2828
Operating Vin(Min), В3.53.5
Package GroupWSONWSON
Package Size: mm2:W x L, PKGSee datasheet (WSON)See datasheet (WSON)
Special FeaturesJEITA BAT Temp Monitoring (Thermistor Pin),Temp Monitoring (Thermistor Pin),Thermal Regulation,Vin DPM (OK for Solar Power Source)JEITA BAT Temp Monitoring (Thermistor Pin),Temp Monitoring (Thermistor Pin),Thermal Regulation,Vin DPM (OK for Solar Power Source)
USB FeatureN/AN/A
RoHSСовместимСовместим
  • Automatic AC/USB Detection in bq24050/2/5 Using D+/D- pins
    PDF, 134 Кб, Файл опубликован: 25 янв 2010
    Modern day electronic devices, such as cell phones and MP3 players, can usually be powered with either an adapter or USB source through a single input connector using a mini USB cable. For a simple charger, without separate power paths for the system and the battery, the system (including the device transceiver) is powered directly from the battery. If the battery is deeply discharged, it has to
  • Selecting the Best bq2404x/5x/9x Single Cell Battery Charger for your Applicatio
    PDF, 38 Кб, Файл опубликован: 29 ноя 2012
Серия: BQ24052 (2)
  • Semiconductors> Power Management> Battery Management Products> Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24052
