Datasheet Texas Instruments BQ24086 — Даташит
СерияBQ24086
ОДНОЧИПОВАЯ ИС ИС УПРАВЛЕНИЯ ЗАРЯДОМ 750 мА Li-Ion/Li-Pol с терморегулированием
bq2408x 750-mA Single-Chip Li-Ion and Li-Pol Charge Management IC With Thermal Regulation datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 30 дек 2015
BQ24086DRCRBQ24086DRCT
Доступность образцов у производителяДаНет
N12
Pin1010
Package TypeDRCDRC
Industry STD TermVSONVSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY3000250
CarrierLARGE T&RSMALL T&R
МаркировкаCDWCDW
Width (мм)33
Length (мм)33
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Parameters / ModelsBQ24086DRCR
BQ24086DRCR
BQ24086DRCT
BQ24086DRCT
Absolute Vin (safety rating)(Max)(, В2020
Battery Charge Voltage(Max), В4.24.2
Battery Charge Voltage(Min), В4.24.2
Cell ChemistryLi-Ion/Li-PolymerLi-Ion/Li-Polymer
Charge Current(Max), A0.750.75
Control InterfaceStandalone (RC-Settable)Standalone (RC-Settable)
Control TopologyLinearLinear
Number of Series Cells11
Operating Vin(Max), В6.56.5
Operating Vin(Min), В4.354.35
Package GroupVSONVSON
Package Size: mm2:W x L, PKG10VSON: 9 mm2: 3 x 3(VSON)10VSON: 9 mm2: 3 x 3(VSON)
Special FeaturesIntegrated FET,Temp Monitoring (Thermistor Pin),Thermal RegulationIntegrated FET,Temp Monitoring (Thermistor Pin),Thermal Regulation
USB FeatureN/AN/A
RoHSСовместимСовместим
  • Achieving Different Charge Voltage for bq2408x
    PDF, 110 Кб, Файл опубликован: 29 апр 2009
    By changing standard 4.2-V charge voltage to 4.1 V or lower, rechargeable lithium-ion (Li-ion) battery cycle life can be extended at low temperature. For new chemistry such as LiFePO4 rechargeable battery, it requires 3.6-V charge voltage. All these new applications need a nonstandard charge voltage. This application report gives examples of using the 4.2-V bq24085 charger to achieve different cha
  • How to Achieve Power-Path Management Function for bq2408x (Rev. A)
    PDF, 174 Кб, Версия: A, Файл опубликован: 21 апр 2009
    This application report presents a simple external circuit for achieving a power-path management function while maintaining an overvoltage protection function and blocking reverse current for low-cost linear battery chargers such as the bq2408x . Brief design criteria and a trade-off study with test results are presented.
Серия: BQ24086 (2)
  • Semiconductors> Power Management> Battery Management Products> Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24086
