Datasheet Texas Instruments BQ24108 — Даташит
СерияBQ24108
Автономное синхронное импульсное литий-ионное зарядное устройство с полевым транзистором 2 А в QFN-20, 1 ячейка
bq241xx Synchronous Switched-Mode, Li-Ion and Li-Polymer Charge-Management IC With Integrated Power FETs (bqSWITCHERв„ў) datasheet
PDF, 1.5 Мб, Версия: P, Файл опубликован: 30 ноя 2015
BQ24108RHLRBQ24108RHLRG4
Доступность образцов у производителяДаДа
N12
Pin2020
Package TypeRHLRHL
Industry STD TermVQFNVQFN
JEDEC CodeR-PQFP-NR-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаCIUCIU
Width (мм)3.53.5
Length (мм)4.54.5
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Parameters / ModelsBQ24108RHLR
BQ24108RHLR
BQ24108RHLRG4
BQ24108RHLRG4
Absolute Vin (safety rating)(Max)(, В2020
Battery Charge Voltage(Max), В4.24.2
Battery Charge Voltage(Min), В4.24.2
Cell ChemistryLi-Ion/Li-PolymerLi-Ion/Li-Polymer
Charge Current(Max), A22
Control InterfaceStandalone (RC-Settable)Standalone (RC-Settable)
Control TopologySwitch-Mode BuckSwitch-Mode Buck
Number of Series Cells11
Operating Vin(Max), В1616
Operating Vin(Min), В4.354.35
Package GroupVQFNVQFN
Package Size: mm2:W x L, PKG20VQFN: 16 mm2: 3.5 x 4.5(VQFN)20VQFN: 16 mm2: 3.5 x 4.5(VQFN)
Special FeaturesIntegrated FET,Temp Monitoring (Thermistor Pin)Integrated FET,Temp Monitoring (Thermistor Pin)
USB FeatureN/AN/A
RoHSСовместимСовместим
  • Power Dissipation Analysis & Circuit Design for Sync Switching Battery Charger
    PDF, 402 Кб, Файл опубликован: 31 май 2005
    The bqSWITCHER(TM) (bq24100/03/05/08/13/15) is a highly integrated, switch-mode, Li-ion and Li-polymer battery charger IC. With two power MOSFETs, the gate drivers, and the controller fully integrated in the chip, the circuit design as well as the PCB layout has been appreciably simplified. However, it is still important to have a good understanding of the charger circuit design, layout principles
  • Implementations of Battery Charger and Power-Path Mgmt System Using bq241xx
    PDF, 752 Кб, Файл опубликован: 6 июн 2006
    This application report presents four system topologies that can be used to fully implement a portable power management system solution using the bqSWITCHERв„ў. Test results and the advantages and issues of each topology are discussed.
  • Drive High Current LEDs
    PDF, 437 Кб, Файл опубликован: 25 янв 2007
    This application report presents high-current LED driving requirements that use the TI integrated boost converter IC TPS6106x and integrated buck converter IC bqSWITCHERв„ў (bq2410x/11x/12x). Step-by-step design procedures, measurement results, and two dimming methods are provided and discussed.
Серия: BQ24108 (2)
  • Semiconductors> Power Management> Battery Management Products> Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24108
