Datasheet Texas Instruments BQ24300DSGR — Даташит
СерияBQ24300
МодельBQ24300DSGR
Микросхема защиты передней части зарядного устройства с максимальным напряжением Vin 30 В и LDO-выходом 5,5 В 8-WSON от 0 до 125
Overvoltage and Overcurrent Protection IC & Li+ Charger Front-End Protection IC datasheet
PDF, 1.9 Мб, Версия: C, Файл опубликован: 4 дек 2009
29 предложений от 17 поставщиков
Микросхема Чип управления батареи, Charger Front End Protection Charger front end protection IC with 30V max Vin and 5.5V LDO output...
BQ24300DSGR
18 ₽
BQ24300DSGR
22 ₽
BQ24300DSGR
727GS
BQ24300DSGR
Package TypeDSG
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаBZA
Width (мм)2
Length (мм)2
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Communication InterfaceNo Communication
FunctionCharger Front-End Protection
Input Over-Current Protection0.3 A
Input Over-Voltage Protection10.5 В
Number of Series Cells1 Min
Package GroupWSON
Protection FeatureOver-voltage (OV) s
Special FeaturesN/A
Typical Operating Current(Typ)340 uA
Vin(Max)30 В
  • Battery-charger front-end IC improves charging-system safety
    PDF, 199 Кб, Файл опубликован: 16 май 2008
  • How to Meet 24V Hot Plug-In Test for Charge Front-End bq243xx
    PDF, 112 Кб, Файл опубликован: 2 янв 2008
    The maximum input voltage rating of the bq243xx family of ICs is 30 V. However, some customers like to perform a 24-V hot plug-in transient test to prove its high-voltage capability and reliability from a system level. It is important for system designers to properly design the charging system with correct system-level protections. Usually, a TVS (transient voltage suppression) Zener diode is used
  • High Voltage Pulse Transient Safety Design fro bq243xx
    PDF, 611 Кб, Файл опубликован: 4 дек 2007
    The maximum input voltage rating of the bq243xx family is 30 V. However, some customers like to do high-voltage pulse transient tests to prove its high-voltage capability and reliability from a system level. This pulse transient voltage could be as high as 45 V with 1-A output current limit and 200-Вµs pulse width. It is important for system designers to properly design the charging system wi
  • Extending Single Input Charger to Dual Input Applications (Rev. A)
    PDF, 256 Кб, Версия: A, Файл опубликован: 21 сен 2009
  • Q2 2008 Issue Analog Applications Journal
    PDF, 1.3 Мб, Файл опубликован: 16 май 2008
    This document holds articles for specific application examples and technologies. It also includes a selection guide for antennas in low-power RF applications.
Серия: BQ24300 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ24300DSGR
