Datasheet Texas Instruments BQ24316DSGTG4 — Даташит
| Серия | BQ24316 |
| Модель | BQ24316DSGTG4 |
Микросхема защиты передней части зарядного устройства с максимальным напряжением 30 В и OVP 6,8 В 8-WSON от -40 до 85
bq2431x Overvoltage and Overcurrent Protection IC and Li+ Charger Front-End Protection IC datasheet
PDF, 2.2 Мб, Версия: D, Файл опубликован: 29 апр 2016
Купить BQ24316DSGTG4 на РадиоЛоцман.Цены — от 30 до 99 ₽12 предложений от 12 поставщиков Микросхема Чип управления батареи, Charger front end protection IC with 30V max Vin and 6.8V OVP 8-WSON -40℃ to 85℃ | |||
| BQ24316DSGTG4 Texas Instruments | 44 ₽ | ||
| BQ24316DSGTG4 Texas Instruments | 52 ₽ | ||
| BQ24316DSGTG4 Texas Instruments | 99 ₽ | ||
| BQ24316DSGTG4 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | DSG |
| Industry STD Term | WSON |
| JEDEC Code | S-PDSO-N |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Маркировка | CBW |
| Width (мм) | 2 |
| Length (мм) | 2 |
| Thickness (мм) | .75 |
| Pitch (мм) | .5 |
| Max Height (мм) | .8 |
| Mechanical Data | Скачать |
| Communication Interface | No Communication |
| Function | Charger Front-End Protection |
| Input Over-Current Protection | 1 A |
| Input Over-Voltage Protection | 6.8 В |
| Number of Series Cells | 1 Min |
| Package Group | WSON |
| Protection Feature | Over-voltage (OV) s |
| Rating | Catalog |
| Special Features | N/A |
| Typical Operating Current(Typ) | 400 uA |
| Vin(Max) | 30 В |
- How to Meet 24V Hot Plug-In Test for Charge Front-End bq243xxPDF, 112 Кб, Файл опубликован: 2 янв 2008
The maximum input voltage rating of the bq243xx family of ICs is 30 V. However, some customers like to perform a 24-V hot plug-in transient test to prove its high-voltage capability and reliability from a system level. It is important for system designers to properly design the charging system with correct system-level protections. Usually, a TVS (transient voltage suppression) Zener diode is used - High Voltage Pulse Transient Safety Design fro bq243xxPDF, 611 Кб, Файл опубликован: 4 дек 2007
The maximum input voltage rating of the bq243xx family is 30 V. However, some customers like to do high-voltage pulse transient tests to prove its high-voltage capability and reliability from a system level. This pulse transient voltage could be as high as 45 V with 1-A output current limit and 200-Вµs pulse width. It is important for system designers to properly design the charging system wi - Extending Single Input Charger to Dual Input Applications (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 21 сен 2009
Серия: BQ24316 (5)
- BQ24316DSGR BQ24316DSGT BQ24316DSGTG4 BQ24316DSJR BQ24316DSJT
- Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
