Datasheet Texas Instruments BQ24316DSJT — Даташит
СерияBQ24316
МодельBQ24316DSJT
Микросхема защиты передней части зарядного устройства с максимальным напряжением 30 В и OVP 6,8 В 12-VSON от -40 до 85
bq2431x Overvoltage and Overcurrent Protection IC and Li+ Charger Front-End Protection IC datasheet
PDF, 2.2 Мб, Версия: D, Файл опубликован: 29 апр 2016
42 предложений от 16 поставщиков
Микросхема Чип управления батареи, Charger Front End Protection Charger front end protection IC with 30V max Vin and 6.8V OVP Battery...
BQ24316DSJT
42 ₽
BQ24316DSJT
67 ₽
Эиком
BQ24316DSJT
от 107 ₽
BQ24316DSJT
Pin12
Package TypeDSJ
Industry STD TermVSON
JEDEC CodeR-PDSO-N
Package QTY250
CarrierSMALL T&R
МаркировкаBZC
Width (мм)4
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Communication InterfaceNo Communication
FunctionCharger Front-End Protection
Input Over-Current Protection1 A
Input Over-Voltage Protection6.8 В
Number of Series Cells1 Min
Package GroupVSON
Protection FeatureOver-voltage (OV) s
Special FeaturesN/A
Typical Operating Current(Typ)400 uA
Vin(Max)30 В
  • How to Meet 24V Hot Plug-In Test for Charge Front-End bq243xx
    PDF, 112 Кб, Файл опубликован: 2 янв 2008
    The maximum input voltage rating of the bq243xx family of ICs is 30 V. However, some customers like to perform a 24-V hot plug-in transient test to prove its high-voltage capability and reliability from a system level. It is important for system designers to properly design the charging system with correct system-level protections. Usually, a TVS (transient voltage suppression) Zener diode is used
  • High Voltage Pulse Transient Safety Design fro bq243xx
    PDF, 611 Кб, Файл опубликован: 4 дек 2007
    The maximum input voltage rating of the bq243xx family is 30 V. However, some customers like to do high-voltage pulse transient tests to prove its high-voltage capability and reliability from a system level. This pulse transient voltage could be as high as 45 V with 1-A output current limit and 200-Вµs pulse width. It is important for system designers to properly design the charging system wi
  • Extending Single Input Charger to Dual Input Applications (Rev. A)
    PDF, 256 Кб, Версия: A, Файл опубликован: 21 сен 2009
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ24316DSJT
