Datasheet Texas Instruments BQ26500PW — Даташит
СерияBQ26500
МодельBQ26500PW
Полный указатель уровня заряда аккумулятора для одно- и двухэлементных литий-ионных систем 8-TSSOP от 0 до 70
bq26500 Single Cell Li-Ion and Li-Pol Battery Gas Gauge IC datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 9 окт 2003
20 предложений от 17 поставщиков
Микросхема Чип управления батареи, TEXAS INSTRUMENTS BQ26500PW Li-Ion, Li-Pol Battery Fuel Gauge IC, 2.6V to 4.5V supply, Serial interface, TSSOP-8
BQ26500PW
857 ₽
Элитан
BQ26500PW
1 080 ₽
BQ26500PW
BQ26500PW
Package TypePW
Industry STD TermTSSOP
Package QTY100
Маркировка26500
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementBQ27010DRKR
Replacement CodeF
  • Evaluation Modules & Boards: BQ26500EVM-001
    bq26500 Evaluation System
  • Configuring the bq26500 for Gas Gauging Applications
    PDF, 132 Кб, Файл опубликован: 15 сен 2003
    This application note describes the ten EEPROM locations that can be programmed by the user to optimize the setup for the particular battery and host requirements.
  • Determining the Values to Program the bq26500/bq26501 EEPROM
    PDF, 326 Кб, Файл опубликован: 17 июн 2004
    Customers can program ten EEPROM registers to optimize the ability of the bq26500/bq26501 to monitor the battery capacity of a given group or type of Li-ion pack cells. This document explains how to obtain the values to be programmed in EEPROM by using information known by the pack/system designers and manufacturers and data collected from packs. HP34401A multimeters and a test setup that includes
  • Multicell Li-Ion and Li-Pol Battery Gas-Gauge Application Using bq26500
    PDF, 185 Кб, Файл опубликован: 29 янв 2004
    The bq26500 is the first complete battery fuel gauge for handheld devices such as PDAs and cellular handsets. Many of these applications use only one Li-Ion or Li-Polymer cell in the battery, producing a nominal 3.6 V. Although optimized for single-cell applications, the bq26500 works well in systems using multicell battery packs, particularly two series-cell batteries producing 7.2 V. This applic
  • Choosing Between Battery Gas Gauges & Monitors to Track Charge Availabilility
    PDF, 184 Кб, Файл опубликован: 27 сен 2005
    Some customers are unfamiliar with battery monitors or gas gauges for their handheld portable applications. The intent of this application report is to provide information about TI product families that are excellent options when selecting a battery gas gauge solution.
  • HDQ Compatibility Between OMAP and BQ Products
    PDF, 76 Кб, Файл опубликован: 17 июн 2004
    TI OMAP? and battery management products are found in today's fast-paced developing market of handheld products that include cellular phones with integrated camera and video recorder features, PDAs with wireless capabilities, and advanced handheld gaming systems. In many of these systems, both OMAP and battery management products coexist. OMAP platforms have an HDQ engine that is used to communica
  • Complete battery-pack design for one- or two-cell portable applications
    PDF, 164 Кб, Файл опубликован: 17 июл 2006
  • HDQ Communication Basics (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 18 сен 2008
    This report compares the communication timing specifications for the different battery gas gauge and battery monitor products. It discusses some of the interface requirements necessary for robust HDQ communication, such as the need for a break prior to each communication, how to reliably read 16-bit dynamic values over the 8-bit bus, and the need for some noise filtering on the HDQ line. It also
  • ESD and RF Mitigation in Handheld Battery Pack Electronics
    PDF, 68 Кб, Файл опубликован: 6 мар 2008
    It is imperative to protect the electronics in a consumer-removable battery pack from ESD damage. Even an upset without permanent damage may be unacceptable to the end-user. Handheld equipment that contains a transmitter also may require protection to guard against improper measurement and/or upset due to the affect of the radio frequency (RF) on the circuitry. Because the RF field strength varies
  • MSP430 Microcontroller SW for Handheld Fuel Gauges and Battery Authentication (Rev. A)
    PDF, 350 Кб, Версия: A, Файл опубликован: 26 май 2010
    MSP430, bq26100, bq26100EVM, bq26150, bq26150EVM, bq26500, bq27000, bq27000EVM, bq27200, b MSP430 Microcontroller Software for Handheld Fuel Gauge & Battery Authentication
Серия: BQ26500 (4)
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
На английском языке: Datasheet Texas Instruments BQ26500PW
