Datasheet Texas Instruments BQ27000 — Даташит
СерияBQ27000
Микросхема манометра для одноэлементных литий-ионных и литий-полимерных аккумуляторов
Single-Cell Li-Ion and Li-Pol Battery Gas Gauge IC For Portable Applications datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 27 фев 2006
BQ27000DRKRBQ27000DRKRG4
Статус продуктаНе рекомендуется для новых разработокНе рекомендуется для новых разработок
N12
Pin1010
Package TypeDRKDRK
Industry STD TermVSONVSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка2700027000
Width (мм)33
Length (мм)44
Thickness (мм).88.88
Pitch (мм).5.5
Max Height (мм)11
RoHSСовместимСовместим
  • Configuring the bq27000/200 for Gas Gauge Applications
    PDF, 137 Кб, Файл опубликован: 29 авг 2005
    Users of the bq27000 and bq27200 ICs can program ten EEPROM locations to optimize setups for particular battery and host requirements. This application report describes how to configure these ICs for those requirements.
  • Building a Superior Battery Monitor with the bq27x00
    PDF, 43 Кб, Файл опубликован: 20 июн 2005
    The bq27x00 is a complete gas gauge solution for lithium-ion and lithium-polymer batteries. The bq27x00 also has internal registers and control commands that enable the host to use it as a battery monitor. A battery gas gauge solution can be built one of two ways: ignore all algorithms built into the bq27x00 and use the primitive functions to build a fully customized solution, or use some of the h
  • Using the bq27x00 With a Primary Cell Battery
    PDF, 42 Кб, Файл опубликован: 15 дек 2005
    The bq27x00 is an accurate coulomb counter and contains algorithms to dynamically compensate the available capacity for temperature and discharge rate. If direct drive from the gauge to an LED display is not required, the bq27x00 can be used as an accurate gas gauge solution for a primary cell battery. Although the bq27x00 was designed for a single-cell rechargeable lithium-ion or lithium-polymer
  • Multicell Li-Ion and Li-Pol Battery Gas-Gauge Application Using the bqJunior
    PDF, 58 Кб, Файл опубликован: 26 май 2006
    The bqJuniorв„ў series of gas gauges are designed to operate from a single-cell, lithium-ion or lithium-polymer battery. Many applications that could benefit from using these gas gauges use two or more lithium cells in series, where the battery voltage exceeds the operating voltage for the bqJuniorв„ў gas gauges. This application report describes a low-component count solution for using th
  • Battery Authentication and Security Schemes (Rev. A)
    PDF, 52 Кб, Версия: A, Файл опубликован: 17 июл 2014
  • Choosing Between Battery Gas Gauges & Monitors to Track Charge Availabilility
    PDF, 184 Кб, Файл опубликован: 27 сен 2005
    Some customers are unfamiliar with battery monitors or gas gauges for their handheld portable applications. The intent of this application report is to provide information about TI product families that are excellent options when selecting a battery gas gauge solution.
  • Complete battery-pack design for one- or two-cell portable applications
    PDF, 164 Кб, Файл опубликован: 17 июл 2006
  • HDQ Communication Basics (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 18 сен 2008
    This report compares the communication timing specifications for the different battery gas gauge and battery monitor products. It discusses some of the interface requirements necessary for robust HDQ communication, such as the need for a break prior to each communication, how to reliably read 16-bit dynamic values over the 8-bit bus, and the need for some noise filtering on the HDQ line. It also
  • ESD and RF Mitigation in Handheld Battery Pack Electronics
    PDF, 68 Кб, Файл опубликован: 6 мар 2008
    It is imperative to protect the electronics in a consumer-removable battery pack from ESD damage. Even an upset without permanent damage may be unacceptable to the end-user. Handheld equipment that contains a transmitter also may require protection to guard against improper measurement and/or upset due to the affect of the radio frequency (RF) on the circuitry. Because the RF field strength varies
  • Feature Set Comparison of bq27x00, bq27x10, bq27500, and bq27510 (Rev. A)
    PDF, 65 Кб, Версия: A, Файл опубликован: 2 дек 2008
    Feature Set Comparison of bq27x00, bq27x10, bq27500 and bq27510
  • Single Cell Impedance Track Printed-Circuit Board Layout
    PDF, 403 Кб, Файл опубликован: 22 фев 2008
    bq20z70/90 Printed-Circuit Board Layout Guide
  • Single Cell Gas Gauge Circuit Design
    PDF, 154 Кб, Файл опубликован: 22 фев 2008
  • MSP430 Microcontroller SW for Handheld Fuel Gauges and Battery Authentication (Rev. A)
    PDF, 350 Кб, Версия: A, Файл опубликован: 26 май 2010
    MSP430, bq26100, bq26100EVM, bq26150, bq26150EVM, bq26500, bq27000, bq27000EVM, bq27200, b MSP430 Microcontroller Software for Handheld Fuel Gauge & Battery Authentication
Серия: BQ27000 (2)
  • Semiconductors> Power Management> Battery Management Products> Battery Fuel Gauge
На английском языке: Datasheet Texas Instruments BQ27000
