Datasheet Texas Instruments BQ27010DRKRG4 — Даташит
СерияBQ27010
МодельBQ27010DRKRG4
Микросхема манометра для литий-ионных и литий-полимерных аккумуляторов для портативных устройств (bqJUNIOR) 10-VSON от -20 до 70
Li-Ion and Li-Pol Battery Gas Gauge IC for Portable Apps (bqJUNIOR) datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 16 янв 2007
IC GAS GAUGE LI-ION/LI-POL 10SON. Battery Battery Monitor IC Lithium Ion/Polymer 10-VSON (3x4). PMIC - Battery Management
BQ27010DRKRG4
106 ₽
BQ27010DRKRG4
295 ₽
Hi-Tech Circuit Group
BQ27010DRKRG4
727GS
BQ27010DRKRG4
Pin10
Package TypeDRK
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY3000
Маркировка27010
Width (мм)3
Length (мм)4
Thickness (мм).88
Pitch (мм).5
Max Height (мм)1
Рекомендуемая замена
ReplacementBQ27220YZFR
Replacement CodeF
  • Evaluation Modules & Boards: BQ27010EVM
    Single-Cell Battery Fuel Gauge
  • Evaluation Modules & Boards: BQ27X00-TESTER
    Test System for BQ27000 BQ27200 Based Circuit Boards
  • Evaluation Modules & Boards: EV2300
    USB-Based PC Interface Board for Battery Fuel (Gas) Gauge Evaluation
  • Configuring the bq27010/210 for Gas Gauge Applications
    PDF, 252 Кб, Файл опубликован: 23 фев 2007
    Accurate performance of the bq27x10 gas gauge requires that the 10 user-configurable EEPROM coefficients be programmed to values that reflect the appropriate host system and battery characteristics. This application report provides the basis for determining the optimal EEPROM coefficients from the host system operational characteristics and battery characterization data. Appendix A specifically ad
  • Transition From Prior bqJunior Gauges to the bq27x10
    PDF, 64 Кб, Файл опубликован: 17 июл 2007
  • Using the bq27x00 With a Primary Cell Battery
    PDF, 42 Кб, Файл опубликован: 15 дек 2005
    The bq27x00 is an accurate coulomb counter and contains algorithms to dynamically compensate the available capacity for temperature and discharge rate. If direct drive from the gauge to an LED display is not required, the bq27x00 can be used as an accurate gas gauge solution for a primary cell battery. Although the bq27x00 was designed for a single-cell rechargeable lithium-ion or lithium-polymer
  • Multicell Li-Ion and Li-Pol Battery Gas-Gauge Application Using the bqJunior
    PDF, 58 Кб, Файл опубликован: 26 май 2006
    The bqJuniorв„ў series of gas gauges are designed to operate from a single-cell, lithium-ion or lithium-polymer battery. Many applications that could benefit from using these gas gauges use two or more lithium cells in series, where the battery voltage exceeds the operating voltage for the bqJuniorв„ў gas gauges. This application report describes a low-component count solution for using th
  • Building a Superior Battery Monitor with the bq27x00
    PDF, 43 Кб, Файл опубликован: 20 июн 2005
    The bq27x00 is a complete gas gauge solution for lithium-ion and lithium-polymer batteries. The bq27x00 also has internal registers and control commands that enable the host to use it as a battery monitor. A battery gas gauge solution can be built one of two ways: ignore all algorithms built into the bq27x00 and use the primitive functions to build a fully customized solution, or use some of the h
  • Battery Authentication and Security Schemes (Rev. A)
    PDF, 52 Кб, Версия: A, Файл опубликован: 17 июл 2014
  • HDQ Communication Basics (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 18 сен 2008
    This report compares the communication timing specifications for the different battery gas gauge and battery monitor products. It discusses some of the interface requirements necessary for robust HDQ communication, such as the need for a break prior to each communication, how to reliably read 16-bit dynamic values over the 8-bit bus, and the need for some noise filtering on the HDQ line. It also
  • ESD and RF Mitigation in Handheld Battery Pack Electronics
    PDF, 68 Кб, Файл опубликован: 6 мар 2008
    It is imperative to protect the electronics in a consumer-removable battery pack from ESD damage. Even an upset without permanent damage may be unacceptable to the end-user. Handheld equipment that contains a transmitter also may require protection to guard against improper measurement and/or upset due to the affect of the radio frequency (RF) on the circuitry. Because the RF field strength varies
  • Feature Set Comparison of bq27x00, bq27x10, bq27500, and bq27510 (Rev. A)
    PDF, 65 Кб, Версия: A, Файл опубликован: 2 дек 2008
    Feature Set Comparison of bq27x00, bq27x10, bq27500 and bq27510
  • Single Cell Impedance Track Printed-Circuit Board Layout
    PDF, 403 Кб, Файл опубликован: 22 фев 2008
    bq20z70/90 Printed-Circuit Board Layout Guide
  • Single Cell Gas Gauge Circuit Design
    PDF, 154 Кб, Файл опубликован: 22 фев 2008
  • MSP430 Microcontroller SW for Handheld Fuel Gauges and Battery Authentication (Rev. A)
    PDF, 350 Кб, Версия: A, Файл опубликован: 26 май 2010
    MSP430, bq26100, bq26100EVM, bq26150, bq26150EVM, bq26500, bq27000, bq27000EVM, bq27200, b MSP430 Microcontroller Software for Handheld Fuel Gauge & Battery Authentication
Серия: BQ27010 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
На английском языке: Datasheet Texas Instruments BQ27010DRKRG4
