Datasheet Texas Instruments BQ29311PWRG4 — Даташит
СерияBQ29311
МодельBQ29311PWRG4
3-, 4-элементная интегральная схема литий-ионной защиты для использования с BQ2083/5 24-TSSOP от -25 до 85
bq29311 - Three- and 4-Cell Lithium-Ion or Lithium-Polymer Battery Protection IC datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 19 сен 2002
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка29311PW
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
  • Avoiding Clock Jitter with the bq2085 Advanced Gas Gauge
    PDF, 147 Кб, Файл опубликован: 20 окт 2003
    The internal-oscillator performance of the TI bq2085 advanced gas-gauge device depends on proper printed-circuit board layout of the external 113-kilohm resistor and phase-locked loop filter components. Component placement, grounding, and crosstalk avoidance must be carefully considered in the layout.
  • bq2083 and bq2085 Board Offset Characterization and Compensation
    PDF, 134 Кб, Файл опубликован: 30 янв 2004
    The bq208x (bq2083, bq2084, and bq2085) products are high-precision advanced gas gauge products for battery monitoring and management. Because the current signal ismeasured through a small sense resistor (< 20 m?? to minimize power loss, compensation for the ADC input offset is critical for the accuracy of the measurement. This application note discusses common issues associated with board offse
  • Cell-Balancing in the bq208x Advanced Gas Gauge Solutions
    PDF, 571 Кб, Файл опубликован: 17 мар 2004
    Serial connection of cells in a battery pack can result in reduced-capacity performance if some of the cells have different capacity or charge levels. The problem is that during charging or discharging of the pack, individual cell differences lead to different voltages ineach cell. Since the charger monitors only the summary voltage, some cells can be undercharged and others overcharged. Underch
  • Multicell Li-Ion and Li-Pol Battery Gas-Gauge Application Using bq26500
    PDF, 185 Кб, Файл опубликован: 29 янв 2004
    The bq26500 is the first complete battery fuel gauge for handheld devices such as PDAs and cellular handsets. Many of these applications use only one Li-Ion or Li-Polymer cell in the battery, producing a nominal 3.6 V. Although optimized for single-cell applications, the bq26500 works well in systems using multicell battery packs, particularly two series-cell batteries producing 7.2 V. This applic
Серия: BQ29311 (4)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ29311PWRG4
