Клеммники KEEN SIDE
Datasheet Texas Instruments BQ29312PWRG4 — Даташит
СерияBQ29312
МодельBQ29312PWRG4
Защита двух-, трех- и четырехэлементных литиевых или литий-полимерных батарей AFE 24-TSSOP от -25 до 85
Three and Four Cell Lithium or Lithium-Polymer Battery Protection AFE datasheet
PDF, 799 Кб, Версия: E, Файл опубликован: 2 мар 2005
Микросхема Чип управления батареи, Battery Protection Li-Ion/Li-Pol 0.2mA 25V 24Pin TSSOP T/R
BQ29312PWRG4
189 ₽
BQ29312PWRG4
197 ₽
BQ29312PWRG4
754 ₽
Hi-Tech Circuit Group
BQ29312PWRG4
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка29312PW
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
  • bq2083 and bq2085 Board Offset Characterization and Compensation
    PDF, 134 Кб, Файл опубликован: 30 янв 2004
    The bq208x (bq2083, bq2084, and bq2085) products are high-precision advanced gas gauge products for battery monitoring and management. Because the current signal ismeasured through a small sense resistor (< 20 m?? to minimize power loss, compensation for the ADC input offset is critical for the accuracy of the measurement. This application note discusses common issues associated with board offse
  • Cell-Balancing in the bq208x Advanced Gas Gauge Solutions
    PDF, 571 Кб, Файл опубликован: 17 мар 2004
    Serial connection of cells in a battery pack can result in reduced-capacity performance if some of the cells have different capacity or charge levels. The problem is that during charging or discharging of the pack, individual cell differences lead to different voltages ineach cell. Since the charger monitors only the summary voltage, some cells can be undercharged and others overcharged. Underch
  • Comparing the bq29312A to the bq29312
    PDF, 137 Кб, Файл опубликован: 7 мар 2005
    The bq29312A analog front end (AFE) IC contains a minor change to the existing bq29312 AFE that improves overall system-level ESD performance. The specifications of the bq29312 and bq29312A are identical.
  • Multicell Li-Ion and Li-Pol Battery Gas-Gauge Application Using bq26500
    PDF, 185 Кб, Файл опубликован: 29 янв 2004
    The bq26500 is the first complete battery fuel gauge for handheld devices such as PDAs and cellular handsets. Many of these applications use only one Li-Ion or Li-Polymer cell in the battery, producing a nominal 3.6 V. Although optimized for single-cell applications, the bq26500 works well in systems using multicell battery packs, particularly two series-cell batteries producing 7.2 V. This applic
Серия: BQ29312 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ29312PWRG4
