Datasheet Texas Instruments BQ29411DCTT — Даташит
СерияBQ29411
МодельBQ29411DCTT
Вторичная защита от перенапряжения для 2–4 элементов последовательно Li-Ion/Poly (4,40 В) 8-SM8 от -40 до 110
Voltage Protection for 2-, 3-, or 4-Cell Li-Ion Batteries (2nd Level Protection) datasheet
PDF, 1.0 Мб, Версия: G, Файл опубликован: 18 авг 2008
Pin88
Package TypeDCTDCT
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаWCJH
Width (мм)2.82.8
Length (мм)2.952.95
Thickness (мм)1.291.29
Pitch (мм).65.65
Max Height (мм)1.31.3
Рекомендуемая замена
ReplacementBQ294704DSGT
Replacement CodeF
  • Stacking Multiple bqq2941x Li-Ion Secondary Voltage Protectors
    PDF, 62 Кб, Файл опубликован: 27 авг 2007
    Li-ion battery applications, requiring five or more series cells, can make use of standard 4-series-cell secondary protectors, such as the bq2941x series. The devices can be stacked as necessary and outputs of individual devices can be combined with optocouplers to produce a single alarm signal if any cell exceeds the threshold. In addition, for undervoltage protection, TLV3011 nanopower comparato
  • Five to Eight-Series-Cell bq20z80 Fuel Gauge
    PDF, 997 Кб, Файл опубликован: 10 сен 2007
    Battery fuel gauging applications requiring five- to eight-series cells may not have an obvious solution. While fully functional solutions are anticipated in the future, currently available chipsets tend to address end-products where four-series cells are the maximum. This report presents an inexpensive solution, using the bq20z80 fuel gauge.
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ29411DCTT
