Datasheet Texas Instruments BQ29414PWR — Даташит
СерияBQ29414
МодельBQ29414PWR
Вторичная защита от перенапряжения для последовательно соединенных 2–4 элементов Li-Ion/Poly (4,55 В) 8-TSSOP от -40 до 110
Datasheet
TSP
28 предложений от 16 поставщиков
Микросхема Чип управления батареи, Lithium Ion Protection Secondary Over-Voltage Protection for 2-4 cell in series Li-Ion/Poly (4.55V) Battery Protection Li-Ion 2V...
BQ29414PWR
37 ₽
BQ29414PWR
41 ₽
Эиком
BQ29414PWR
от 119 ₽
SUV System
BQ29414PWR
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка2914
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
  • Stacking Multiple bqq2941x Li-Ion Secondary Voltage Protectors
    PDF, 62 Кб, Файл опубликован: 27 авг 2007
    Li-ion battery applications, requiring five or more series cells, can make use of standard 4-series-cell secondary protectors, such as the bq2941x series. The devices can be stacked as necessary and outputs of individual devices can be combined with optocouplers to produce a single alarm signal if any cell exceeds the threshold. In addition, for undervoltage protection, TLV3011 nanopower comparato
  • Five to Eight-Series-Cell bq20z80 Fuel Gauge
    PDF, 997 Кб, Файл опубликован: 10 сен 2007
    Battery fuel gauging applications requiring five- to eight-series cells may not have an obvious solution. While fully functional solutions are anticipated in the future, currently available chipsets tend to address end-products where four-series cells are the maximum. This report presents an inexpensive solution, using the bq20z80 fuel gauge.
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ29414PWR
