Datasheet Texas Instruments BQ34Z100PWR-G1 — Даташит
СерияBQ34Z100-G1
МодельBQ34Z100PWR-G1
Автономный датчик уровня топлива с мультихимической импедансной системой | Манометр аккумуляторной батареи 14-ТССОП от -40 до 85
bq34z100-G1 Wide Range Fuel Gauge with Impedance Trackв„ў Technology datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 25 июл 2016
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка34Z100
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Battery Capacity(Max)29000 mAh
Battery Capacity(Min)100 mAh
Cell BalancingN/A
Cell ChemistryLead Acid,Li-Ion/Li-Polymer,LiFePO4,NiCd,NiMH
Communication InterfaceHDQ,I2C
External Capacity IndicationLED
Gas Gauge AlgorithmIT (High accuracy)
ImplementationPack,System
Number of Series Cells2-4 Cells,>4 Cells,Single Cell
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Pin/Package14TSSOP
Special FeaturesSHA-1 Authentication
RoHSНе совместим
  • Evaluation Modules & Boards: BQ34Z100EVM
    Bq34z100EVM 1s to 16s Impedance Track Fuel Gauge Battery Evaluation Module | Gas Gauge Battery
  • bq34z100-G1 High Cell Count and High Capacity Applications
    PDF, 71 Кб, Файл опубликован: 29 сен 2015
    The bq34z100-G1 device is configurable to provide gauging for Li-Ion, Li-Polymer, LiFePO4, lead acid (PbA), NiMH and NiCd cell chemistries. The gauge can support charge and discharge currents up to 32 A, pack capacities up to 29 Ah, and pack voltages up to 65 V without special setups. This document provides information to setup the gauge to support packs that exceed these current, capacity, or vol
  • Using I2C Communications With the bq34110 bq35100 and bq34z100-G1 Series of Gas
    PDF, 264 Кб, Файл опубликован: 9 ноя 2016
Серия: BQ34Z100-G1 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
BQ34Z100PWRG1, BQ34Z100PWR G1
На английском языке: Datasheet Texas Instruments BQ34Z100PWR-G1
Публикации по теме
