Datasheet Texas Instruments BQ76200PWR — Даташит
СерияBQ76200
МодельBQ76200PWR
Драйвер N-канального полевого транзистора верхнего плеча 16-TSSOP от -40 до 85
bq76200 High Voltage Battery Pack Front-End Charge/Discharge High-Side NFET Driver datasheet
PDF, 1.8 Мб, Файл опубликован: 30 ноя 2015
53 предложений от 18 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Управление батареями
BQ76200PWR
от 69 ₽
Hi-Tech Circuit Group
BQ76200PWR
BQ76200PWR
727GS
BQ76200PWR
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаBQ7620B
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Communication InterfaceNo Communication
FunctionCharge/Discharge Driver
Number of Series Cells3 Max
Package GroupTSSOP
Protection FeatureN/A s
Special FeaturesHigh-Side NCH CHG/DSG FET Drive
Typical Operating Current(Typ)40 uA
Vin(Max)75 В
  • Evaluation Modules & Boards: BQ76200EVM-606
    bq76200 100V Battery Pack High–Side Dual NCH FET Driver Evaluation Module
  • bq76200 Reverse Voltage Considerations
    PDF, 149 Кб, Файл опубликован: 3 янв 2017
    The bq76200 high-side, N-channel FET driver does not allow pins to go negative. While it may becommon to have a flyback diode as shown in the EVM, some systems may want to allow the PACK+ to gonegative. This document describes a circuit and test results that assist in the successful implementation ofa reverse voltage circuit in a bq76200 battery application.
  • FET Configurations for the bq76200 High-Side N-Channel FET Driver (Rev. A)
    PDF, 8.9 Мб, Версия: A, Файл опубликован: 15 фев 2016
    The bq76200 is a low-power, high-side, N-Channel MOSFET driver that can be utilized in a variety of FETconfigurations to assist the user’s battery protection system from faults such as a cell’s undervoltage andovervoltage or a short circuit. The following material is aimed to portray various applications of thebq76200 with several different configurations of FETs, pack voltages, and cell cou
  • bq76200 Beyond the Simple Application Schematic
    PDF, 347 Кб, Файл опубликован: 30 янв 2017
    The bq76200 high-side N-channel FET driver is a highly-integrated solution to control FETs in a batterymanagement circuit. The simple circuit in the data sheet can be effective in many applications, but theuser may encounter situations where the device does not appear to switch as expected or unexpecteddamage occurs. This document describes the switching operation of the bq76200 and shows ho
  • Minimizing Shutdown Current of the bq76200
    PDF, 102 Кб, Файл опубликован: 12 дек 2016
    The bq76200 high-side N-channel FET driver has a quiescent supply current even when disabled. Whilethe current is low, in some applications it is desirable to minimize load current during times when thebattery is idle. This document describes a circuit and test result that assists in the successfulimplementation of a battery switch circuit when shutting down the bq76200.
Серия: BQ76200 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ76200PWR
