Datasheet Texas Instruments BQ76PL455A-Q1 — Даташит
СерияBQ76PL455A-Q1
Монитор 16-элементной батареи с пассивной балансировкой ячеек
bq76PL455A-Q1 16-Cell EV/HEV Integrated Battery Monitor and Protector datasheet
PDF, 2.3 Мб, Версия: C, Файл опубликован: 3 ноя 2016
BQ76PL455A
BQ76PL455ATPFCRQ1BQ76PL455ATPFCTQ1
Доступность образцов у производителяНетДа
N12
Pin8080
Package TypePFCPFC
Industry STD TermTQFPTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY1000250
CarrierLARGE T&RSMALL T&R
Маркировка76PL455ATQ176PL455ATQ1
Width (мм)1212
Length (мм)1212
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsBQ76PL455ATPFCRQ1
BQ76PL455ATPFCRQ1
BQ76PL455ATPFCTQ1
BQ76PL455ATPFCTQ1
Communication InterfaceDifferential Daisy ChainDifferential Daisy Chain
FunctionMonitoring (Analog Front-End)Monitoring (Analog Front-End)
Number of Series Cells, Max66
Package GroupTQFPTQFP
Protection Feature, sOver-temperature (OT),Over-voltage (OV),Under-voltage (UV)Over-temperature (OT),Over-voltage (OV),Under-voltage (UV)
RatingAutomotiveAutomotive
Special FeaturesCell Balancing,Integrated ADC,Programmable EEPROM or EPROM,Requires separate MCU,Stackable (built-in interface)Cell Balancing,Integrated ADC,Programmable EEPROM or EPROM,Requires separate MCU,Stackable (built-in interface)
Typical Operating Current(Typ), uA50005000
Vin(Max), В79.279.2
RoHSСовместимСовместим
  • Getting Started with the bq76PL455A-Q1 Example Code
    PDF, 70 Кб, Файл опубликован: 22 сен 2015
    This application report explains the implementation of a multi-cell lithium-ion the foundation of a battery management system using an TMS570в„ў microcontroller and the bq76PL455A-Q1.The bq76PL455A-Q1 can be stacked vertically to monitor up to 192 cells without additional isolation components between ICs. A high-speed universal asynchronous receiver/transmitter (UART) bus operates between the b
  • bq76PL455A-Q1 Use Case Scenarios
    PDF, 1.5 Мб, Файл опубликован: 5 янв 2017
    The bq76PL455A-Q1 is used several different ways for system creation. This document describes the known ways a bq76PL455A-Q1 is used in a battery pack.
  • bq76PL455A-Q1 Software Design Reference (Rev. A)
    PDF, 133 Кб, Версия: A, Файл опубликован: 11 май 2015
  • bq76PL455A-Q1 Design Consideration
    PDF, 512 Кб, Файл опубликован: 31 окт 2016
  • Designing EMI/EMC Safe Battery Pack
    PDF, 65 Кб, Файл опубликован: 14 июн 2016
Серия: BQ76PL455A-Q1 (2)
  • Semiconductors> Power Management> Battery Management Products> Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ76PL455A-Q1
