Клеммники KEEN SIDE
Datasheet Texas Instruments BQ76PL536PAPR — Даташит
СерияBQ76PL536
МодельBQ76PL536PAPR
Монитор литий-ионного аккумулятора и ИС вторичной защиты для электромобилей и гибридных электромобилей 64-HTQFP от -40 до 85
3 to 6 Series Cell Lithium-Ion Battery Monitor and Secondary Protection IC datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 7 июл 2010
Pin64
Package TypePAP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаBQ76PL536
Width (мм)10
Length (мм)10
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Рекомендуемая замена
ReplacementBQ76PL536APAPR
Replacement CodeQ
  • Evaluation Modules & Boards: BQ76PL536PGM-1
    Programming Board for BQ76PL536A/BQ76PL536A-Q1 Lithium-Ion Battery Monitor and Secondary Protection
  • Improving Communications With the bq76PL536
    PDF, 158 Кб, Файл опубликован: 11 авг 2010
    The bq76PL536 is designed to communicate at high speed in noisy conditions present in automotive and industrial large-format battery applications. This document presents specific steps to maximize the integrity of communications with the bq76PL536 and reduce susceptibility to noise to a minimum, thereby reducing the bit-error rate to an acceptable level.
  • bq76PL536/536A/536AQ1 Communication Basics (Rev. B)
    PDF, 71 Кб, Версия: B, Файл опубликован: 5 июл 2011
    This application report discusses the communication basics of addressing, reading, and writing for the Texas Instruments bq76PL536, a stackable 3-to-6 series battery pack protector and analog front end.
  • Multi-Cell Li-Ion Battery Management System Using MSP430F5529 and bq76PL536
    PDF, 118 Кб, Файл опубликован: 16 дек 2010
    This application report explains the implementation of a multi-cell lithium-ion battery management system using an MSP430(tm) microcontroller and the bq76PL536. The battery manager is implemented using the standard evaluation boards for the MSP430 MCU and the bq76PL536.The bq76PL536 can be stacked vertically to monitor up to 192 cells without additional isolation components between ICs. A high-s
Серия: BQ76PL536 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ76PL536PAPR
