Datasheet Texas Instruments BQ7790400PW — Даташит
СерияBQ77904
МодельBQ7790400PW
3-4S Маломощный предохранитель 20-TSSOP от -40 до 85
bq77905, bq77904 3-5S Ultra Low-Power Voltage, Current, Temperature, and Open Wire Stackable Lithium-ion Battery Protector datasheet
PDF, 1.6 Мб, Версия: G, Файл опубликован: 13 сен 2017
41 предложений от 15 поставщиков
Устройство защиты Li-Ion батареи по напряжению, току, температуре и открытому контуру, 3В до 20В
BQ7790400PW
164 ₽
Эиком
BQ7790400PW
от 238 ₽
BQ7790400PW
от 240 ₽
BQ7790400PW
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY70
МаркировкаB7790400
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Communication InterfaceNo Communication
FunctionProtection
Number of Series Cells3 Max
Package GroupTSSOP
Protection FeatureOpen wire detection,Over-current in Discharge (OCD),Over-temperature (OT),Over-voltage (OV),Short-circuit Discharge (SCD),Under-temperature (UT),Under-voltage (UV) s
Special FeaturesAnalog current sense,Low-Side NCH CHG/DSG FET Drive,Programmable EEPROM or EPROM,Stackable (built-in interface),Temperature sense
Typical Operating Current(Typ)6 uA
Vin(Max)25 В
  • Evaluation Modules & Boards: BQ77905EVM-707
    bq77905 3- to 5-Series Advanced Stackable Low-Power Battery Protector Evaluation Module
  • bq77905 Shutdown for Current Reduction
    PDF, 231 Кб, Файл опубликован: 21 июл 2017
    The bq77905 3-5S Low-Power Protector for lithium-ion batteries features a low 6-ОјA typical supply currentto extend battery life. Power tools or other applications where the battery is in storage or unused for longperiods may want to prevent battery discharge during idle times. The schematic examples and test resultsin this document help the battery electronics designer when implementing a ci
Серия: BQ77904 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ7790400PW
