Datasheet Texas Instruments BQ78PL116RGZT — Даташит
СерияBQ78PL116
МодельBQ78PL116RGZT
Главный шлюзовой контроллер PowerLAN с технологией балансировки ячеек PowerPump 48-VQFN от -40 до 85
PowerLAN Master Gateway Controller With PowerPump Cell Balancing Technology datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 5 янв 2011
25 предложений от 15 поставщиков
Микросхема Чип управления батареи, TEXAS INSTRUMENTS BQ78PL116RGZT Li-Ion Battery Fuel Gauge, 2.5V to 4.5V supply, SMBus interface, VQFN-48
BQ78PL116RGZT
от 471 ₽
BQ78PL116RGZT
1 407 ₽
BQ78PL116RGZT
2 104 ₽
ТаймЧипс
BQ78PL116RGZT
Pin4848
Package TypeRGZRGZ
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
Маркировка78PL116BQ
Width (мм)77
Length (мм)77
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
  • What is a .tmap File? (Rev. A)
    PDF, 294 Кб, Версия: A, Файл опубликован: 10 мар 2011
    The PowerLANв„ў Master Gateway Battery Management Controller uses a file, identified by the .tmap file extension, to load configuration parameters. This file serves to configure the operation of the controller to the specific application. Examples of configurable parameters are number of parallel and series cells in the pack, number of temperature sensors, and state-of-charge indication (SOCi) dis
  • SBData Commands For PowerLAN(TM) Master Gateway Controller
    PDF, 109 Кб, Файл опубликован: 14 апр 2011
    The Smart Battery Data (SBData) Interface is a list of commands that have become a standard in lithium-ion battery management applications. The bq78PL116 supports this standard command set and also includes additional commands to allow some control of its unique operation. These additional commands are called SBData Commands for the PowerLANв„ў Master Gateway Controller and use standard SMBus tran
  • Chemistry Selection for the bq78PL114 (Rev. B)
    PDF, 146 Кб, Версия: B, Файл опубликован: 12 фев 2010
  • PowerPump(TM) Balancing (Rev. B)
    PDF, 721 Кб, Версия: B, Файл опубликован: 26 окт 2011
    Pack based charging and discharging schemes cannot fully address the problems associated with capacity imbalance of the series cells. Balancing at the cell level is needed to maximize pack performance. PowerPumpв„ў Cell Balancing is a feature provided in the bq78PL114 and bq76PL102 PowerLANв„ў devices that transfers charge between cells using a boost-type power converter topology. Results are faster a
  • Wide-Vin Battery-Charger Using SMBus MSP430 MCUs and bq Fuel Gauges (Rev. A)
    PDF, 1.0 Мб, Версия: A, Файл опубликован: 25 июл 2011
    This application report describes a smart-battery charger reference design with a wide-input-voltage range. The reference design implements the System Management Bus (SMBus) protocol for communication between the MSP430 microcontroller and a SMBus-compatible battery fuel gauge. The MSP430 device interrogates the fuel gauge for voltage, current, and other parameters via SMBus. It then adjusts the p
Серия: BQ78PL116 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
На английском языке: Datasheet Texas Instruments BQ78PL116RGZT
