Datasheet Texas Instruments CC1100RTKG3 — Даташит
СерияCC1100
МодельCC1100RTKG3
Single-Chip Low Cost Low Power RF-Transceiver datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 29 май 2009
IC RF TXRX ISM. IC RF TxRx Only General ISM < 1ghz='' 300mhz='' ~='' 348mhz,='' 400mhz='' ~='' 464mhz,='' 800mhz='' ~='' 928mhz=''...
Рутоника
CC1100RTKG3
428 ₽
CC1100RTKG3
444 ₽
CC1100RTKG3
Xinhuo Future
CC1100RTKG3
Pin20
Package TypeRTK
Industry STD TermVQFNP
JEDEC CodeS-PQFP-N
Package QTY92
МаркировкаCC1100
Width (мм)4
Length (мм)4
Thickness (мм).85
Pitch (мм).5
Max Height (мм).9
  • Daughter Cards: CC1150EMK-868
    CC1150EMK Evaluation Module 868 MHz
  • DN009 -- Upgrading from CC1100 to CC1101 (Rev. A)
    PDF, 63 Кб, Версия: A, Файл опубликован: 16 июл 2009
  • Clear Channel Assessment Using TI MSP430 and CC2500 Radio
    PDF, 950 Кб, Файл опубликован: 31 июл 2007
    This application report describes a 2.4-GHz anti-jamming frequency-hopping system consisting of a designated Transmitter and Receiver, each with distinct functions to avoid RF-channel interference. The Transmitter board emulates the control device (e.g., remote control) by sending commands to be processed on the Receiver side (e.g., TV, stereo, set top box, or gaming console). Since many popular c
  • AN047 -- CC1100/CC2500 Wake on Radio (Rev. B)
    PDF, 220 Кб, Версия: B, Файл опубликован: 23 мар 2009
    AN047--CC1100/CC2500 Wake on Radio
  • AN096 Using CC1190 Front End with CC1101 under FCC 15.247 (Rev. A)
    PDF, 563 Кб, Версия: A, Файл опубликован: 2 май 2011
  • Antenna Diversity
    PDF, 556 Кб, Файл опубликован: 23 окт 2014
    This application report provides real-world measurement results showing the benefit of antenna diversity. The CC1200 radio transceiver is used as an example in this design note, but the results are applicable for all TI LPRF radios.
  • AN085 -- Implementing Diversity Using Low Power Radios
    PDF, 459 Кб, Файл опубликован: 26 янв 2010
    CC1101, CC1110, CC2500, CC2510, CC430 Implementing 'Diversity' Using Low Power Radios
  • AN069 -- Low Cost Long Range One Way Audio Communications at 900 MHz (Rev. B)
    PDF, 302 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • DN107 -- DMA and Radio Configuration (Rev. A)
    PDF, 859 Кб, Версия: A, Файл опубликован: 17 дек 2009
  • DN012 -- Programming Output Powers on CC1100 and CC1150 (Rev. A)
    PDF, 511 Кб, Версия: A, Файл опубликован: 2 янв 2008
    This document gives a complete overview of the register settings required to adjust the output power of the CC1100/1 and CC1150 devices. The tables within this document include typical output power, harmonics, and current consumption at the different register settings.
  • DN509 -- Data Whitening and Random TX Mode
    PDF, 183 Кб, Файл опубликован: 12 апр 2010
    This document gives an overview of the data whitening and random data transmission circuitry in the CC430, CC1100, CC1100E, CC1101, CC1110, CC1111, CC1150, CC2500, CC2510, CC2511, and CC2550 devices.
  • AN105 -- Using 1W RF3858 Front End with CC1101 Under FCC 15.247 (Rev. A)
    PDF, 983 Кб, Версия: A, Файл опубликован: 3 авг 2011
  • DN006 -- CC11xx Settings for FCC15.247 Solutions (Rev. B)
    PDF, 105 Кб, Версия: B, Файл опубликован: 17 авг 2010
  • DN025 -- Johanson Technology Matched Balun Filters (Rev. A)
    PDF, 609 Кб, Версия: A, Файл опубликован: 13 окт 2011
  • DN036 -- CC1101+CC1190 600 kbps Data Rate, +19 dBm Transmit (Rev. A)
    PDF, 139 Кб, Версия: A, Файл опубликован: 7 ноя 2011
  • AN094 -- Using the CC1190 Front End with CC1101 under EN 300 220
    PDF, 371 Кб, Файл опубликован: 11 янв 2011
  • AN049 -- Software for CC1100/CC2500 and MSP430 – Examples and Function Library
    PDF, 485 Кб, Файл опубликован: 31 май 2007
    The Software for CC1100/CC2500 and MSP430 - Examples and Function Library is the recommended starting point for developing software for the CC1100/CC2500 and MSP430 combination.The software demonstrates how to use some of the many advanced digital features and packet handling capabilities of the CC1100/CC2500. The software examples have been developed for the MSP430 Experimenter’s Board, but c
  • AN095 -- Continuous Data Streaming Applications - Using Serial Synchronous Mode (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 18 июл 2011
  • DN400 -- Interfacing CC1100 - CC2500 with MSP430 (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 24 мар 2009
  • DN017 -- CC11xx 868/915 MHz RF Matching (Rev. A)
    PDF, 328 Кб, Версия: A, Файл опубликован: 31 мар 2008
    There are three versions of the CC11xx reference design which have been published. This design note gives a short introduction to RF matching and important aspects when designing products using the CC11xx parts and discusses the differences between the three reference design revisions.
  • DN503 -- SPI Access (Rev. B)
    PDF, 94 Кб, Версия: B, Файл опубликован: 22 окт 2007
    The purpose of this design note is to show how the serial peripheral interface (SPI) must be configured to be able to communicate with the CC1100/CC1101/CC1150/CC2500/CC2550. It also shows how the status bytes should be interpreted and how SW reset is done over the SPI interface.
  • DN501 -- PATABLE Access (Rev. B)
    PDF, 66 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • DN500 -- Packet Transmission Basics (Rev. C)
    PDF, 174 Кб, Версия: C, Файл опубликован: 6 апр 2009
  • DN505 -- RSSI interpretation and timing (Rev. D)
    PDF, 129 Кб, Версия: D, Файл опубликован: 16 июн 2010
  • DN111 - Current Consumption for a Polling Receiver (Rev. A)
    PDF, 687 Кб, Версия: A, Файл опубликован: 24 мар 2009
  • AN103 -- Basic RF Testing of CCxxxx Devices
    PDF, 596 Кб, Файл опубликован: 8 авг 2011
    This document presents users of Texas Instruments' low-power RF products with an overview of the different characterization tests (conducted, not radiated) that are performed during the device verification process. The document covers the basic setup of the test system and gives procedural information about each test.
  • DN506 -- GDO Pin Usage (Rev. A)
    PDF, 219 Кб, Версия: A, Файл опубликован: 22 окт 2007
    The purpose of this design note is to explain how to use the different general digital output (GDO) pins for control and monitoring purposes. The focus is set on interfacing with a microcontroller unit (MCU) and is related to the CC1100, CC1101, CC1150, CC2500 and CC2550 devices.
  • DN508 -- Frequency Scanning using CC430Fx, CC110x, and CC111xFx
    PDF, 65 Кб, Файл опубликован: 25 янв 2010
    The purpose of this design note is to show the necessary steps to successfully scan through a frequency band covering n numbers of channels, and find the strongest signal in the band.
  • DN300 -- SmartRF04EB Troubleshooting (Rev. B)
    PDF, 490 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • DN005 -- CC11xx Sensitivity versus Frequency Offset and Crystal Accuracy (Rev. C)
    PDF, 96 Кб, Версия: C, Файл опубликован: 20 авг 2009
  • DN022 -- CC110x CC111x OOK ASK Register Settings (Rev. E)
    PDF, 532 Кб, Версия: E, Файл опубликован: 8 мар 2012
  • DN504 -- FEC Implementation (Rev. A)
    PDF, 110 Кб, Версия: A, Файл опубликован: 22 окт 2007
    This design note explains the functionality of forward error correction (FEC) and how it is used in the CC1100, CC1101, CC1110, CC1111, CC1150, CC2500, CC2510, CC2511, and CC2550 devices. Example code for FEC implementation is included.
  • DN032 -- Options for Cost Optimized CC11xx Matching
    PDF, 112 Кб, Файл опубликован: 25 авг 2010
  • DN016 -- Compact Antenna Solution for 868/915 MHz (Rev. B)
    PDF, 832 Кб, Версия: B, Файл опубликован: 20 авг 2009
  • DN019 -- Powering Low-Power RF Products (Rev. B)
    PDF, 327 Кб, Версия: B, Файл опубликован: 18 сен 2009
  • DN507 -- FEC Decoding
    PDF, 264 Кб, Файл опубликован: 28 янв 2010
    The purpose of this design note is to show how the FEC decoding implemented in HW on the CC1100, CC1100E, CC1101, CC1110Fx, CC1111Fx, CC1150, CC2500, CC2510Fx, CC2511Fx, and CC2550 can be implemented in SW. This is in particular very important for the CC430Fx device, which has the same radio as the CC1101 and CC1110/11Fx but without HW FEC included.
  • DN024 -- 868 MHz, 915 MHz and 955 MHz Monopole PCB Antenna (Rev. E)
    PDF, 1.0 Мб, Версия: E, Файл опубликован: 22 фев 2013
  • DN502 -- CRC Implementation (Rev. D)
    PDF, 55 Кб, Версия: D, Файл опубликован: 27 окт 2009
  • AN001 -- SRD regulations for license free transceiver operation
    PDF, 260 Кб, Файл опубликован: 1 фев 2006
  • DN303 -- Cleanup of Installed PC Tools
    PDF, 545 Кб, Файл опубликован: 20 дек 2006
  • DN033 - Mitsubishi Ceramic Antenna for 868 MHz, 915 MHz & 955 (Rev. A)
    PDF, 685 Кб, Версия: A, Файл опубликован: 14 сен 2010
  • DN023 -- 868 MHz, 915 MHz and 955 MHz Inverted F Antenna (Rev. C)
    PDF, 369 Кб, Версия: C, Файл опубликован: 30 авг 2011
  • AN014 -- Frequency Hopping Systems
    PDF, 210 Кб, Файл опубликован: 1 фев 2006
  • AN028 -- LC Filter with Improved High-Frequency Attenuation
    PDF, 254 Кб, Файл опубликован: 1 фев 2006
    AN028 -- Improved LC Filter
  • AN021 -- Voltage Level Conversion
    PDF, 212 Кб, Файл опубликован: 1 фев 2006
  • DN011 -- RF Module Testing using SmartRF Studio (Rev. A)
    PDF, 325 Кб, Версия: A, Файл опубликован: 23 мар 2009
  • DN018 -- Range Measurements in an Open Field Environment (Rev. A)
    PDF, 607 Кб, Версия: A, Файл опубликован: 15 апр 2008
    This design note is a general description of how to set up open field range measurements and what has to be considered. Applies to all low power RF-ICs.
  • DN002 -- Practical Sensitivity Testing
    PDF, 364 Кб, Файл опубликован: 20 дек 2006
  • AN003 -- SRD Antennas
    PDF, 358 Кб, Файл опубликован: 1 фев 2006
  • DN000 - Design Note Overview (Rev. T)
    PDF, 126 Кб, Версия: T, Файл опубликован: 12 окт 2011
  • DN031 -- CC-Antenna-DK Documentation and Antenna Measurements Summary
    PDF, 2.3 Мб, Файл опубликован: 26 авг 2010
    DN031 -- Design Notes
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
  • Semiconductors > Wireless Connectivity > Companion Wireless Solutions > Smart RF Transceivers
На английском языке: Datasheet Texas Instruments CC1100RTKG3
