Datasheet Texas Instruments CC110LRGPT — Даташит
СерияCC110L
МодельCC110LRGPT
Трансивер Value Line Sub-1 ГГц 20-QFN от -40 до 85
CC110L Value Line Transceiver datasheet
PDF, 949 Кб, Версия: C, Файл опубликован: 12 дек 2016
Pin20
Package TypeRGP
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаCC110L
Width (мм)4
Length (мм)4
Thickness (мм).93
Pitch (мм).5
Max Height (мм)1
Data Rate(Max)600 kbps
Device TypeSmart RF Transceiver
Frequency Bands315,433,779,868,915,920 МГц
RX Current (Lowest)14 мА
Sensitivity (Best)-116 dBm
Special FeaturesN/A
TX Power(Max)12 dBm
TechnologySub-1 GHz
Throughput(Max)0.6 Mbps
  • Daughter Cards: CC11XLEMK-433
    Value Line Evaluation Modules 433MHz
  • Daughter Cards: BOOST-CCEMADAPTER
    EM Adapter BoosterPack
  • Evaluation Modules & Boards: MSP-SA430-SUB1GHZ
    Sub-1 GHz RF Spectrum Analyzer Tool
  • Evaluation Modules & Boards: SMARTRFTRXEBK
    SmartRF Transceiver Evaluation Board
  • Evaluation Modules & Boards: 430BOOST-CC110L
    CC110L RF BoosterPack
  • TI LPRF EASYMODE
    PDF, 57 Кб, Файл опубликован: 12 дек 2014
    This application report describes the frame format and physical layer (PHY) parameters for TI LPRF EasyMode (EasyMode50K), which provides unified, simple, and well defined PHY modes supported by all sub-1 GHz radio devices from LPRF.
  • DN038 -- Miniature Helical PCB Antenna for 868 MHz or 915/920 MHz
    PDF, 905 Кб, Файл опубликован: 27 ноя 2012
    CC1120, CC1121, CC1125, CC1175, CC1200, CC1201, CC1111, CC1101, CC1110, CC110L Miniature Helical PCB Antenna for 868 MHz or 915/920 MHz CC113L, CC115L
  • CC112x-CC1190 Boost Software Examples
    PDF, 55 Кб, Файл опубликован: 19 окт 2015
  • Antenna Diversity
    PDF, 556 Кб, Файл опубликован: 23 окт 2014
    This application report provides real-world measurement results showing the benefit of antenna diversity. The CC1200 radio transceiver is used as an example in this design note, but the results are applicable for all TI LPRF radios.
  • CC-Antenna-DK2 and Antenna Measurements Summary
    PDF, 14.8 Мб, Файл опубликован: 3 мар 2016
    The purpose of the antenna development kit (CC-Antenna-DK2) is to ease the decision of which type of low-cost antenna can be implemented as well as give an estimation of the performance that can be achieved.
Серия: CC110L (2)
  • Semiconductors > Wireless Connectivity > Companion Wireless Solutions > Smart RF Transceivers
На английском языке: Datasheet Texas Instruments CC110LRGPT
