Datasheet Texas Instruments CC115LRGPR — Даташит
СерияCC115L
МодельCC115LRGPR
Передатчик Value Line Sub-1 ГГц 20-QFN от -40 до 85
CC115L Value Line Transmitter datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 8 май 2014
Pin20
Package TypeRGP
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаCC115L
Width (мм)4
Length (мм)4
Thickness (мм).93
Pitch (мм).5
Max Height (мм)1
Data Rate(Max)600 kbps
Device TypeSmart RF Transmitter
Frequency Bands315,433,779,868,915,920 МГц
Special FeaturesN/A
TX Power(Max)12 dBm
TechnologySub-1 GHz
Throughput(Max)0.6 Mbps
  • Daughter Cards: CC11XLEMK-433
    Value Line Evaluation Modules 433MHz
  • Evaluation Modules & Boards: SMARTRFTRXEBK
    SmartRF Transceiver Evaluation Board
  • TI LPRF EASYMODE
    PDF, 57 Кб, Файл опубликован: 12 дек 2014
    This application report describes the frame format and physical layer (PHY) parameters for TI LPRF EasyMode (EasyMode50K), which provides unified, simple, and well defined PHY modes supported by all sub-1 GHz radio devices from LPRF.
  • DN038 -- Miniature Helical PCB Antenna for 868 MHz or 915/920 MHz
    PDF, 905 Кб, Файл опубликован: 27 ноя 2012
    CC1120, CC1121, CC1125, CC1175, CC1200, CC1201, CC1111, CC1101, CC1110, CC110L Miniature Helical PCB Antenna for 868 MHz or 915/920 MHz CC113L, CC115L
  • CC-Antenna-DK2 and Antenna Measurements Summary
    PDF, 14.8 Мб, Файл опубликован: 3 мар 2016
    The purpose of the antenna development kit (CC-Antenna-DK2) is to ease the decision of which type of low-cost antenna can be implemented as well as give an estimation of the performance that can be achieved.
Серия: CC115L (2)
  • Semiconductors > Wireless Connectivity > Companion Wireless Solutions > Smart RF Transceivers
На английском языке: Datasheet Texas Instruments CC115LRGPR
