Datasheet Texas Instruments CC1310F32RHBT — Даташит
СерияCC1310
МодельCC1310F32RHBT
Беспроводной микроконтроллер SimpleLink™ с частотой менее 1 ГГц и сверхнизким энергопотреблением 32-VQFN от -40 до 85
CC1310 SimpleLinkв„ў Ultra-Low-Power Sub-1 GHz Wireless MCU datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 24 окт 2016
Pin3232
Package TypeRHBRHB
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierLARGE T&RLARGE T&R
МаркировкаCC1310F32
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Data Rate(Max)4000 kbps
Device TypeWireless MCU
Flash128 KB
Frequency BandsSub-1 GHz МГц
RAM size20 KB
RX Current (Lowest)5.5 мА
Security EnablerCryptographic acceleration,Debug security,Device identity,Software IP protection
Sensitivity (Best)-124 dBm
TX Power(Max)14 dBm
TechnologySub-1 GHz
Throughput(Max)4.0 Mbps
    XDS200 USB Debug Probe
  • Evaluation Modules & Boards: LAUNCHXL-CC1310
    SimpleLinkВ™ Sub-1 GHz CC1310 wireless microcontroller (MCU) LaunchPadВ™ development kit
  • Development Kits: LAUNCHXL-CC1350
    SimplelinkВ™ Sub-1 GHz & BluetoothВ® low energy CC1350 wireless MCU LaunchPadВ™ Dev Kit
  • Development Kits: CC-ANTENNA-DK2
    Sub-1 GHz and 2.4 GHz Antenna Kit for LaunchPadВ™ and SensorTag
  • CC1310 Skyworks PA 433 MHz 20 dBm Reference Design Rev 2.x
    PDF, 505 Кб, Файл опубликован: 2 май 2017
    The frequency range 426 MHz - 435 MHz is designated for ISM applications in several countries. This frequency range is commonly known as the 433 MHz band. Each country has their specific frequency band range and the China ISM band defined by SRRC is 430 MHz - 432 MHz and 433.00 MHz - 434.79 MHz.
  • CC1310 Skyworks PA Chinese AMR Reference Design Rev 2.x
    PDF, 649 Кб, Файл опубликован: 12 дек 2016
    This application report is targeting the Chinese AMR market (470 MHz to 510 MHz) with CC1310. To enhance the wireless operation range in China, TI provides the range extender reference design. The initial design was based upon a discrete PA solution. To simplify the RF front design, TI worked with Skyworks Solutions to integrate the CC1310 wireless MCU with a compact, cost-effective front-end modu
  • Using the CC13xx Under ARIB STD-T108
    PDF, 1.1 Мб, Файл опубликован: 24 авг 2015
    This application report outlines the expected performance when operating CC1310 under ARIB STD-T108 in the 920 MHz frequency band. It is assumed that you are familiar with CC1310 and ARIB STD-T108 regulatory limits. Lab measurements show that CC1310 meets ARIB STD-T108 requirements.
  • CC1310 Integrated Passive Component for 779-928 MHz (Rev. A)
    PDF, 3.0 Мб, Версия: A, Файл опубликован: 6 дек 2016
  • Using CC1190 Front End With CC13xx Under EN300220
    PDF, 238 Кб, Файл опубликован: 9 мар 2017
  • Using CC1190 Front End With CC13xx Under FCC 15.247
    PDF, 218 Кб, Файл опубликован: 9 мар 2017
  • Wireless Motion Detector With Sub-1 GHz SimpleLinkв„ў Wireless MCU
    PDF, 374 Кб, Файл опубликован: 18 май 2017
    This application note discusses the main challenges related to wireless motion detector design and how they are addressed by the SimpleLink Sub-1 GHz CC1310 and SimpleLink Dual-band CC1350 wireless MCUs. First, the application note gives a short overview of a wireless motion detector. Then the application report discusses the wireless technology requirements which must be met to support motion det
  • CC1310 Discrete PA Chinese AMR Reference Design Rev 1.x
    PDF, 811 Кб, Файл опубликован: 12 дек 2015
    Automatic Meter Reading (AMR) automatically collects the information on the amount of water, electric or gas that has been consumed by each household. When the AMR information is received, the exact energy amount can be charged from the energy supplier company. Traditionally, this has been done by manual reading of meters, but this can now be done automatically with wireless technology.Seve
  • Wireless Smoke Alarms With Sub-1GHz SimpleLink Wireless MCU
    PDF, 146 Кб, Файл опубликован: 22 июн 2017
    This application report discusses the main challenges related to wireless smoke alarm designs and how they are addressed by the CC1310 and CC1350 wireless MCUs.
  • CC13x0 IQ Samples
    PDF, 172 Кб, Файл опубликован: 16 авг 2017
    This application report describes an IQ dump patch for the CC13xx SimpleLinkв„ў Sub-1 GHz ultra-low power wireless microcontroller (MCU).
  • CC13xx wM-Bus S-Mode
    PDF, 223 Кб, Файл опубликован: 31 мар 2017
    This application note describes a wM-Bus S-mode patch for the CC13xx SimpleLinkв„ў Sub-1 GHz ultra-lowpower wireless microcontroller (MCU). Measurements show that CC13xx meets EN13757-4:2012 specifications with margin.
  • Wireless Door and Window Sensors With Sub-1GHz SimpleLink Wireless MCU
    PDF, 89 Кб, Файл опубликован: 26 сен 2017
    This application report discusses the main challenges related to wireless door and window sensor design and how they are addressed by CC1310 and CC1350 wireless MCU. First it gives a short overview of what a wireless door and window sensor is. Then, it discusses wireless technology requirements for door and window sensors and other security system use-cases. The application report validates the Su
  • CC13x0 Low Data Rate Operation
    PDF, 147 Кб, Файл опубликован: 26 июн 2017
  • CC13xx Antenna Diversity (Rev. B)
    PDF, 2.0 Мб, Версия: B, Файл опубликован: 31 мар 2017
    This application report describes a preamble quality-based antenna-diversity patch for the CC13xxSimpleLinkв„ў Sub-1 GHz ultra-low power wireless microcontroller (MCU).
  • CC13xx Combined wM-Bus C-Mode and T-Mode Application Note (Rev. D)
    PDF, 703 Кб, Версия: D, Файл опубликован: 31 мар 2017
    This application note describes a combined wM-Bus C-Mode and T-Mode patch for the CC13xxSimpleLinkв„ў Sub-1 GHz ultra-low power wireless microcontroller.
  • Achieving Optimum Radio Range (Rev. A)
    PDF, 8.7 Мб, Версия: A, Файл опубликован: 5 сен 2017
    This application report addresses the parameters that affect the radio range. For identical radio settings, the range is highly dependent on the surroundings and environment. The link budget and the positioning of the antennas and their distance to the ground surface are major contributors to long range. A general specific range can never be specified or guaranteed for any type of radio communicat
  • Using GCC/GDB With SimpleLink CC26xx
    PDF, 1.0 Мб, Файл опубликован: 23 фев 2015
    This application report describes how to set up an open source software-based development environment for the SimpleLink CC26xx and CC13xx wireless MCUs using Eclipse as integrated development environment (IDE).
  • Crystal Oscillator and Crystal Selection for the CC26xx and CC13xx Wireless MCUs (Rev. F)
    PDF, 886 Кб, Версия: F, Файл опубликован: 10 авг 2017
  • CC2640 Wireless MCU DC Supply Evaluation
    PDF, 1.3 Мб, Файл опубликован: 5 окт 2015
    CC2640 Wireless MCU DC Supply Evaluation /WTBU/WCS/Bluetooth/AppReports/SWRA494/SWRA494
  • CC2538/CC26xx Bootloader Interface (Rev. A)
    PDF, 277 Кб, Версия: A, Файл опубликован: 21 май 2015
    This application report provides a brief overview on the serial bootloader that resides in ROM on the CC2538 and CC13xx/CC26xx devices. This document shows how the bootloader protocol can be used to perform basic operations like erasing and programming the flash of the devices. The device bootloaders support universal asynchronous receiver/transmitter (UART) and serial peripheral interface (SPI) a
  • CC-Antenna-DK2 and Antenna Measurements Summary
    PDF, 14.8 Мб, Файл опубликован: 3 мар 2016
    The purpose of the antenna development kit (CC-Antenna-DK2) is to ease the decision of which type of low-cost antenna can be implemented as well as give an estimation of the performance that can be achieved.
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
  • Semiconductors > Wireless Connectivity > Sub-1 GHz > SimpleLink CC1310
На английском языке: Datasheet Texas Instruments CC1310F32RHBT
