Datasheet Texas Instruments CC1350F128RSMT — Даташит
СерияCC1350
МодельCC1350F128RSMT
Двухдиапазонный беспроводной микроконтроллер SimpleLink™ со сверхнизким энергопотреблением 32-VQFN от -40 до 85
CC1350 SimpleLinkв„ў Ultra-Low-Power Dual-Band Wireless MCU datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 21 ноя 2016
Pin3232
Package TypeRSMRSM
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаCC1350F128
Width (мм)44
Length (мм)44
Thickness (мм).9.9
Pitch (мм).4.4
Max Height (мм)11
Bluetooth StandardBluetooth low energy
Data Rate(Max)4000 kbps
Device TypeWireless MCU
Package GroupVQFN
Package Size: mm2:W x L32VQFN: 16 mm2: 4 x 4(VQFN) PKG
Security EnablerCryptographic acceleration,Debug security,Device identity,Software IP protection
TechnologyMulti-standard,Sub-1 GHz,Bluetooth low energy (BLE)
Throughput(Max)4.0 Mbps
  • Evaluation Modules & Boards: LAUNCHXL-CC1350-4
    CC1350 Dualband Launchpad for 433MHz/2.4GHz Applications
    XDS200 USB Debug Probe
  • Development Kits: CC1350STK
    Simplelink CC1350 SensorTag Bluetooth and Sub-1GHz Long Range Wireless Development Kit
  • Evaluation Modules & Boards: LAUNCHXL-CC1310
    SimpleLinkВ™ Sub-1 GHz CC1310 wireless microcontroller (MCU) LaunchPadВ™ development kit
  • Development Kits: LAUNCHXL-CC1350
    SimplelinkВ™ Sub-1 GHz & BluetoothВ® low energy CC1350 wireless MCU LaunchPadВ™ Dev Kit
  • Development Kits: CC-ANTENNA-DK2
    Sub-1 GHz and 2.4 GHz Antenna Kit for LaunchPadВ™ and SensorTag
  • CC1350 Dual Band Launchpad for 433 MHz/2.4 GHz Bands (Rev. A)
    PDF, 12.7 Мб, Версия: A, Файл опубликован: 22 сен 2017
    The LAUNCHXL-CC1350-4 module (CC1350 dual band Launchpad for 433 MHz/2.4 GHz) combines a BluetoothВ® Smart with a 433 MHz radio for the ultimate combination of easy mobile phone integration with long range connectivity including a 32-bit ARMВ® CortexВ®-M3 processor on a single chip. The module can be used as a LaunchPad kit and as well as in SmartRFв„ў evaluation board application. The
  • Wireless Door and Window Sensors With Sub-1GHz SimpleLink Wireless MCU
    PDF, 89 Кб, Файл опубликован: 26 сен 2017
    This application report discusses the main challenges related to wireless door and window sensor design and how they are addressed by CC1310 and CC1350 wireless MCU. First it gives a short overview of what a wireless door and window sensor is. Then, it discusses wireless technology requirements for door and window sensors and other security system use-cases. The application report validates the Su
  • Wireless Smoke Alarms With Sub-1GHz SimpleLink Wireless MCU
    PDF, 146 Кб, Файл опубликован: 22 июн 2017
    This application report discusses the main challenges related to wireless smoke alarm designs and how they are addressed by the CC1310 and CC1350 wireless MCUs.
  • Wireless Motion Detector With Sub-1 GHz SimpleLinkв„ў Wireless MCU
    PDF, 374 Кб, Файл опубликован: 18 май 2017
    This application note discusses the main challenges related to wireless motion detector design and how they are addressed by the SimpleLink Sub-1 GHz CC1310 and SimpleLink Dual-band CC1350 wireless MCUs. First, the application note gives a short overview of a wireless motion detector. Then the application report discusses the wireless technology requirements which must be met to support motion det
  • CC1310 Discrete PA Chinese AMR Reference Design Rev 1.x
    PDF, 811 Кб, Файл опубликован: 12 дек 2015
    Automatic Meter Reading (AMR) automatically collects the information on the amount of water, electric or gas that has been consumed by each household. When the AMR information is received, the exact energy amount can be charged from the energy supplier company. Traditionally, this has been done by manual reading of meters, but this can now be done automatically with wireless technology.Seve
  • CC13x0 IQ Samples
    PDF, 172 Кб, Файл опубликован: 16 авг 2017
    This application report describes an IQ dump patch for the CC13xx SimpleLinkв„ў Sub-1 GHz ultra-low power wireless microcontroller (MCU).
  • CC13xx wM-Bus S-Mode
    PDF, 223 Кб, Файл опубликован: 31 мар 2017
    This application note describes a wM-Bus S-mode patch for the CC13xx SimpleLinkв„ў Sub-1 GHz ultra-lowpower wireless microcontroller (MCU). Measurements show that CC13xx meets EN13757-4:2012 specifications with margin.
  • CC13x0 Low Data Rate Operation
    PDF, 147 Кб, Файл опубликован: 26 июн 2017
  • CC13xx Antenna Diversity (Rev. B)
    PDF, 2.0 Мб, Версия: B, Файл опубликован: 31 мар 2017
    This application report describes a preamble quality-based antenna-diversity patch for the CC13xxSimpleLinkв„ў Sub-1 GHz ultra-low power wireless microcontroller (MCU).
  • CC13xx Combined wM-Bus C-Mode and T-Mode Application Note (Rev. D)
    PDF, 703 Кб, Версия: D, Файл опубликован: 31 мар 2017
    This application note describes a combined wM-Bus C-Mode and T-Mode patch for the CC13xxSimpleLinkв„ў Sub-1 GHz ultra-low power wireless microcontroller.
  • CC2640 Wireless MCU DC Supply Evaluation
    PDF, 1.3 Мб, Файл опубликован: 5 окт 2015
    CC2640 Wireless MCU DC Supply Evaluation /WTBU/WCS/Bluetooth/AppReports/SWRA494/SWRA494
  • Crystal Oscillator and Crystal Selection for the CC26xx and CC13xx Wireless MCUs (Rev. F)
    PDF, 886 Кб, Версия: F, Файл опубликован: 10 авг 2017
  • Semiconductors > Wireless Connectivity > Multi-Standard > SimpleLink CC1350 (BLE+Sub-1)
На английском языке: Datasheet Texas Instruments CC1350F128RSMT
