Datasheet Texas Instruments CC2543RHBR — Даташит
СерияCC2543
МодельCC2543RHBR
SoC RF Value Line 2,4 ГГц с флэш-памятью 32 КБ, 16 GPIO, I2C, SPI и UART 32-VQFN от -40 до 85
CC2543 System-on-Chip for 2.4-GHz RF Applications datasheet
PDF, 921 Кб, Версия: E, Файл опубликован: 3 окт 2013
IC RF TXRX+MCU ISM>1GHZ 32VFQFN. IC RF TxRx + MCU General ISM > 1GHZ 2.4GHz 32-VFQFN Exposed Pad. RF Transceiver ICs...
Рутоника
CC2543RHBR
160 ₽
CC2543RHBR
184 ₽
CC2543RHBR
272 ₽
Xinhuo Future
CC2543RHBR
Pin32
Package TypeRHB
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаCC2543
Width (мм)5
Length (мм)5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Data Rate(Max)2000 kbps
Device TypeWireless MCU
Flash32 KB
Key Software FeaturesBasic software examples for all MCU peripherals and radio
Max VCC3.6
Min VCC2
Modulation TechniquesGFSK,MSK
RAM size1 KB
RX Current (Lowest)21.2 мА
Sensitivity (Best)-98 dBm
TX Power(Max)5 dBm
TechnologyProprietary 2.4 GHz
Throughput(Max)2.0 Mbps
USB 2.0No
  • JTAG Emulators/ Analyzers: CC-DEBUGGER
    Debugger and Programmer for RF System-on-Chips
  • Evaluation Modules & Boards: CC2543-CC2544DK
    CC2543-CC2544 Development Kit
  • AN118 -- Flash programming of CC253x/4x devices
    PDF, 426 Кб, Файл опубликован: 5 сен 2012
    Application note AN118 demonstrates how to use the CC debug interface to perform various flash related tasks on CC253x / CC254x System-on-Chips. It is distributed along with a example code using a CC2530 as a programmer – but is easily ported to other devices. The application note explains in detail the example code, which covers how to enter debug mode and how to read/write/erase the flash memory
  • AN081 -- Johanson Technology Balun Optimized for CC253X, CC254X, CC257X, CC853X (Rev. B)
    PDF, 456 Кб, Версия: B, Файл опубликован: 6 ноя 2012
  • AN098 - Layout Review Techniques for Low Power RF Designs (Rev. A)
    PDF, 456 Кб, Версия: A, Файл опубликован: 2 авг 2012
Серия: CC2543 (2)
  • Semiconductors > Wireless Connectivity > Proprietary 2.4 GHz
На английском языке: Datasheet Texas Instruments CC2543RHBR
