Datasheet Texas Instruments CC2544RHBR — Даташит
| Серия | CC2544 |
| Модель | CC2544RHBR |
SoC RF Value Line 2,4 ГГц с флэш-памятью 32 КБ, USB, SPI и UART 32-VQFN от -40 до 125
CC2544 System-on-Chip for 2.4-GHz USB Applications datasheet
PDF, 920 Кб, Версия: D, Файл опубликован: 3 май 2012
Купить CC2544RHBR на РадиоЛоцман.Цены — от 74 до 767 ₽18 предложений от 13 поставщиков Радиочастотная деталь RF, 2.4GHz RF Value Line SoC with 32KB flash, USB, SPI and UART 32-VQFN -40℃ to 125℃ | |||
| CC2544RHBR Texas Instruments | 149 ₽ | ||
| CC2544RHBR Texas Instruments | 165 ₽ | ||
| CC2544RHBR Texas Instruments | по запросу | ||
| Pin | 32 |
| Package Type | RHB |
| Industry STD Term | VQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | CC2544 |
| Width (мм) | 5 |
| Length (мм) | 5 |
| Thickness (мм) | .9 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| Data Rate(Max) | 2000 kbps |
| Device Type | Wireless MCU |
| Flash | 32 KB |
| Key Software Features | Basic software examples for all MCU peripherals and radio |
| Max VCC | 3.6 |
| Min VCC | 2 |
| Modulation Techniques | GFSK,MSK |
| RAM size | 2 KB |
| RX Current (Lowest) | 22.5 мА |
| Rating | Catalog |
| Sensitivity (Best) | -95 dBm |
| TX Power(Max) | 4 dBm |
| Technology | Proprietary 2.4 GHz |
| Throughput(Max) | 2.0 Mbps |
| USB 2.0 | Yes |
- JTAG Emulators/ Analyzers: CC-DEBUGGER
Debugger and Programmer for RF System-on-Chips
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: CC2543-CC2544DK
CC2543-CC2544 Development Kit
- Autonomous high density streaming protocolPDF, 172 Кб, Файл опубликован: 6 авг 2013
This application report describes a new high density streaming protocol that was developed for the new series of ultra-low cost 2.4 GHz System-on-Chip (SoC) devices called CC2543/4/5. With this protocol, it is possible to setup a large number of point-to-point links in the same physical environment. Examples of applications where such a protocol could be used are patient monitoring systems, remote - AN118 -- Flash programming of CC253x/4x devicesPDF, 426 Кб, Файл опубликован: 5 сен 2012
Application note AN118 demonstrates how to use the CC debug interface to perform various flash related tasks on CC253x / CC254x System-on-Chips. It is distributed along with a example code using a CC2530 as a programmer – but is easily ported to other devices. The application note explains in detail the example code, which covers how to enter debug mode and how to read/write/erase the flash memory - AN081 -- Johanson Technology Balun Optimized for CC253X, CC254X, CC257X, CC853X (Rev. B)PDF, 456 Кб, Версия: B, Файл опубликован: 6 ноя 2012
- AN098 - Layout Review Techniques for Low Power RF Designs (Rev. A)PDF, 456 Кб, Версия: A, Файл опубликован: 2 авг 2012
Серия: CC2544 (2)
- CC2544RHBR CC2544RHBT
- Semiconductors > Wireless Connectivity > Proprietary 2.4 GHz
