Datasheet Texas Instruments CC2544RHBT — Даташит
СерияCC2544
МодельCC2544RHBT
SoC RF Value Line 2,4 ГГц с флэш-памятью 32 КБ, USB, SPI и UART 32-VQFN от -40 до 125
CC2544 System-on-Chip for 2.4-GHz USB Applications datasheet
PDF, 920 Кб, Версия: D, Файл опубликован: 3 май 2012
Pin32
Package TypeRHB
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаCC2544
Width (мм)5
Length (мм)5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Data Rate(Max)2000 kbps
Device TypeWireless MCU
Flash32 KB
Key Software FeaturesBasic software examples for all MCU peripherals and radio
Max VCC3.6
Min VCC2
Modulation TechniquesGFSK,MSK
RAM size2 KB
RX Current (Lowest)22.5 мА
Sensitivity (Best)-95 dBm
TX Power(Max)4 dBm
TechnologyProprietary 2.4 GHz
Throughput(Max)2.0 Mbps
USB 2.0Yes
  • JTAG Emulators/ Analyzers: CC-DEBUGGER
    Debugger and Programmer for RF System-on-Chips
  • Evaluation Modules & Boards: CC2543-CC2544DK
    CC2543-CC2544 Development Kit
  • Autonomous high density streaming protocol
    PDF, 172 Кб, Файл опубликован: 6 авг 2013
    This application report describes a new high density streaming protocol that was developed for the new series of ultra-low cost 2.4 GHz System-on-Chip (SoC) devices called CC2543/4/5. With this protocol, it is possible to setup a large number of point-to-point links in the same physical environment. Examples of applications where such a protocol could be used are patient monitoring systems, remote
  • AN118 -- Flash programming of CC253x/4x devices
    PDF, 426 Кб, Файл опубликован: 5 сен 2012
    Application note AN118 demonstrates how to use the CC debug interface to perform various flash related tasks on CC253x / CC254x System-on-Chips. It is distributed along with a example code using a CC2530 as a programmer – but is easily ported to other devices. The application note explains in detail the example code, which covers how to enter debug mode and how to read/write/erase the flash memory
  • AN081 -- Johanson Technology Balun Optimized for CC253X, CC254X, CC257X, CC853X (Rev. B)
    PDF, 456 Кб, Версия: B, Файл опубликован: 6 ноя 2012
  • AN098 - Layout Review Techniques for Low Power RF Designs (Rev. A)
    PDF, 456 Кб, Версия: A, Файл опубликован: 2 авг 2012
Серия: CC2544 (2)
  • Semiconductors > Wireless Connectivity > Proprietary 2.4 GHz
На английском языке: Datasheet Texas Instruments CC2544RHBT
