Datasheet Texas Instruments CC2545RGZT — Даташит
СерияCC2545
МодельCC2545RGZT
SoC RF Value Line 2,4 ГГц с флэш-памятью 32 КБ, 31 GPIO, I2C, SPI и UART 48-VQFN от -40 до 85
CC2545 System-on-Chip for 2.4-GHz RF Applications datasheet
PDF, 927 Кб, Версия: B, Файл опубликован: 3 фев 2013
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаCC2545
Width (мм)7
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Data Rate(Max)2000 kbps
Device TypeWireless MCU
Flash32 KB
Key Software FeaturesBasic software examples for all MCU peripherals and radio
Max VCC3.6
Min VCC2
Modulation TechniquesGFSK,MSK
RAM size1 KB
RX Current (Lowest)20.8 мА
Sensitivity (Best)-98 dBm
TX Power(Max)5 dBm
TechnologyProprietary 2.4 GHz
Throughput(Max)2.0 Mbps
USB 2.0No
  • Evaluation Modules & Boards: CC2545EMK
    CC2545 Evaluation Module Kit
  • JTAG Emulators/ Analyzers: CC-DEBUGGER
    Debugger and Programmer for RF System-on-Chips
  • AN118 -- Flash programming of CC253x/4x devices
    PDF, 426 Кб, Файл опубликован: 5 сен 2012
    Application note AN118 demonstrates how to use the CC debug interface to perform various flash related tasks on CC253x / CC254x System-on-Chips. It is distributed along with a example code using a CC2530 as a programmer – but is easily ported to other devices. The application note explains in detail the example code, which covers how to enter debug mode and how to read/write/erase the flash memory
  • AN098 - Layout Review Techniques for Low Power RF Designs (Rev. A)
    PDF, 456 Кб, Версия: A, Файл опубликован: 2 авг 2012
Серия: CC2545 (2)
  • Semiconductors > Wireless Connectivity > Proprietary 2.4 GHz
На английском языке: Datasheet Texas Instruments CC2545RGZT
