Datasheet Texas Instruments CC2550RSTR — Даташит
СерияCC2550
МодельCC2550RSTR
Single-Chip Low Cost Low Power RF-Transmitter datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 24 окт 2007
32 предложений от 17 поставщиков
Радиочастотный передатчик, Low Cost 2.4GHz Transmitter Designed for Low-Power Wireless Applications in 2.4GHz ISM Band 16-VQFN -40℃ to 85℃
CC2550RSTR
107 ₽
Рутоника
CC2550RSTR
137 ₽
Эиком
CC2550RSTR
от 543 ₽
CC2550RSTR
Pin16
Package TypeRST
Industry STD TermVQFNP
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаCC2550
Width (мм)4
Length (мм)4
Thickness (мм).85
Max Height (мм).95
Рекомендуемая замена
ReplacementCC2500RTKR
Replacement CodeS
  • DN014 -- Programming Output Powers on CC2500 and CC2550
    PDF, 176 Кб, Файл опубликован: 4 окт 2007
    This document gives a complete overview of the register settings required to adjust the output power of the CC2500 and CC2550 devices. The tables within this document include typical output power, harmonics, and current consumption at the different register settings.
  • DN004 Folded Dipole Antenna for CCC25xx
    PDF, 383 Кб, Файл опубликован: 5 дек 2006
    DN00x Folded Dipole Antenna for CCC25xx
  • DN509 -- Data Whitening and Random TX Mode
    PDF, 183 Кб, Файл опубликован: 12 апр 2010
    This document gives an overview of the data whitening and random data transmission circuitry in the CC430, CC1100, CC1100E, CC1101, CC1110, CC1111, CC1150, CC2500, CC2510, CC2511, and CC2550 devices.
  • AN049 -- Software for CC1100/CC2500 and MSP430 – Examples and Function Library
    PDF, 485 Кб, Файл опубликован: 31 май 2007
    The Software for CC1100/CC2500 and MSP430 - Examples and Function Library is the recommended starting point for developing software for the CC1100/CC2500 and MSP430 combination.The software demonstrates how to use some of the many advanced digital features and packet handling capabilities of the CC1100/CC2500. The software examples have been developed for the MSP430 Experimenter’s Board, but c
  • AN095 -- Continuous Data Streaming Applications - Using Serial Synchronous Mode (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 18 июл 2011
  • DN400 -- Interfacing CC1100 - CC2500 with MSP430 (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 24 мар 2009
  • 2.4-GHz Inverted F Antenna (Rev. C)
    PDF, 470 Кб, Версия: C, Файл опубликован: 8 фев 2017
  • DN501 -- PATABLE Access (Rev. B)
    PDF, 66 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • DN500 -- Packet Transmission Basics (Rev. C)
    PDF, 174 Кб, Версия: C, Файл опубликован: 6 апр 2009
  • DN503 -- SPI Access (Rev. B)
    PDF, 94 Кб, Версия: B, Файл опубликован: 22 окт 2007
    The purpose of this design note is to show how the serial peripheral interface (SPI) must be configured to be able to communicate with the CC1100/CC1101/CC1150/CC2500/CC2550. It also shows how the status bytes should be interpreted and how SW reset is done over the SPI interface.
  • AN048 -- 2.4GHz Chip Antenna (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 4 мар 2008
    This application note describes the performance and characteristics of the Compact Reach Xtendв„ў chip antenna. This antenna is specifically designed to operate at 2.4 GHz and combines small size with high performance to improve the functionality of RF devices.
  • AN043 -- Small Size 2.4 GHz PCB Antenna (Rev. D)
    PDF, 2.3 Мб, Версия: D, Файл опубликован: 4 апр 2008
  • AN032 -- 2.4 GHz Regulations
    PDF, 332 Кб, Файл опубликован: 31 янв 2006
  • DN506 -- GDO Pin Usage (Rev. A)
    PDF, 219 Кб, Версия: A, Файл опубликован: 22 окт 2007
    The purpose of this design note is to explain how to use the different general digital output (GDO) pins for control and monitoring purposes. The focus is set on interfacing with a microcontroller unit (MCU) and is related to the CC1100, CC1101, CC1150, CC2500 and CC2550 devices.
  • DN300 -- SmartRF04EB Troubleshooting (Rev. B)
    PDF, 490 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • AN068 - Design Steps and Results for Changing PCB Layer Thickness (Rev. A)
    PDF, 792 Кб, Версия: A, Файл опубликован: 8 окт 2009
  • DN504 -- FEC Implementation (Rev. A)
    PDF, 110 Кб, Версия: A, Файл опубликован: 22 окт 2007
    This design note explains the functionality of forward error correction (FEC) and how it is used in the CC1100, CC1101, CC1110, CC1111, CC1150, CC2500, CC2510, CC2511, and CC2550 devices. Example code for FEC implementation is included.
  • DN507 -- FEC Decoding
    PDF, 264 Кб, Файл опубликован: 28 янв 2010
    The purpose of this design note is to show how the FEC decoding implemented in HW on the CC1100, CC1100E, CC1101, CC1110Fx, CC1111Fx, CC1150, CC2500, CC2510Fx, CC2511Fx, and CC2550 can be implemented in SW. This is in particular very important for the CC430Fx device, which has the same radio as the CC1101 and CC1110/11Fx but without HW FEC included.
  • DN502 -- CRC Implementation (Rev. D)
    PDF, 55 Кб, Версия: D, Файл опубликован: 27 окт 2009
  • DN034 -- YAGI 2.4 GHz PCB Antenna
    PDF, 1.9 Мб, Файл опубликован: 14 окт 2010
  • DN303 -- Cleanup of Installed PC Tools
    PDF, 545 Кб, Файл опубликован: 20 дек 2006
  • AN028 -- LC Filter with Improved High-Frequency Attenuation
    PDF, 254 Кб, Файл опубликован: 1 фев 2006
    AN028 -- Improved LC Filter
  • AN014 -- Frequency Hopping Systems
    PDF, 210 Кб, Файл опубликован: 1 фев 2006
  • DN011 -- RF Module Testing using SmartRF Studio (Rev. A)
    PDF, 325 Кб, Версия: A, Файл опубликован: 23 мар 2009
  • AN021 -- Voltage Level Conversion
    PDF, 212 Кб, Файл опубликован: 1 фев 2006
  • DN018 -- Range Measurements in an Open Field Environment (Rev. A)
    PDF, 607 Кб, Версия: A, Файл опубликован: 15 апр 2008
    This design note is a general description of how to set up open field range measurements and what has to be considered. Applies to all low power RF-ICs.
  • DN002 -- Practical Sensitivity Testing
    PDF, 364 Кб, Файл опубликован: 20 дек 2006
  • AN003 -- SRD Antennas
    PDF, 358 Кб, Файл опубликован: 1 фев 2006
  • DN000 - Design Note Overview (Rev. T)
    PDF, 126 Кб, Версия: T, Файл опубликован: 12 окт 2011
  • DN031 -- CC-Antenna-DK Documentation and Antenna Measurements Summary
    PDF, 2.3 Мб, Файл опубликован: 26 авг 2010
    DN031 -- Design Notes
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
Серия: CC2550 (3)
  • Semiconductors > Wireless Connectivity > Proprietary 2.4 GHz
На английском языке: Datasheet Texas Instruments CC2550RSTR
