Datasheet Texas Instruments CC2564BRVMR — Даташит
СерияCC2564
МодельCC2564BRVMR
Двухрежимный контроллер Bluetooth® 76-VQFNP-MR от -40 до 85
CC256x Dual-Mode Bluetooth Controller datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 12 мар 2014
Pin76
Package TypeRVM
Industry STD TermVQFNP-MR
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаCC2564B
Width (мм)8
Length (мм)8
Thickness (мм).85
Pitch (мм).6
Max Height (мм).9
Bluetooth StandardBluetooth Smart (Bluetooth low energy),Classic Bluetooth,Dual-mode Bluetooth
Data Rate(Max)3000 kbps
Device TypeSmart RF Transceiver
Package GroupVQFNP-MR
Package Size: mm2:W x L76VQFNP-MR: 64 mm2: 8 x 8(VQFNP-MR) PKG
Special FeaturesBluetooth low energy (Bluetooth Smart),Classic Bluetooth
TechnologyBluetooth
Throughput(Max)3 Mbps
  • Evaluation Modules & Boards: EK-TM4C1294XL
    ARMВ® CortexВ®-M4F-Based MCU TM4C1294 Connected LaunchPadв„ў
  • Evaluation Modules & Boards: CC256XSTBTBLESW
    TI Dual-mode BluetoothВ® Stack on STM32F4 MCUs
  • Evaluation Modules & Boards: MSP-EXP430F5529
    MSP430F5529 USB Experimenter’s Board
  • Evaluation Modules & Boards: BT-MSPAUDSOURCE
    Bluetooth and MSP430 Audio Source Reference Design Board
  • Evaluation Modules & Boards: CC2564MODNEM
    Dual-mode BluetoothВ® CC2564 module evaluation board
  • Evaluation Modules & Boards: CC256XQFNEM
    Dual-mode BluetoothВ® CC2564 evaluation board
  • Evaluation Modules & Boards: MSP-EXP430F5438
    MSP430F5438 Experimenter Board
  • Evaluation Modules & Boards: EK-TM4C123GXL
    ARMВ® CortexВ®-M4F Based MCU TM4C123G LaunchPadВ™ Evaluation Kit
  • Development Kits: DK-TM4C123G
    TM4C123G USB+CAN Development Kit
  • Evaluation Modules & Boards: CC2564MODAEM
    Dual-mode BluetoothВ® CC2564 Module with Integrated Antenna Evaluation Board
  • Development Kits: DK-TM4C129X
    IoT Enabled ARMВ® CortexВ®-M4F MCU TM4C129X Connected Development Kit
  • Evaluation Modules & Boards: EK-TM4C129EXL
    ARMВ® CortexВ®-M4F-Based MCU TM4C129E Crypto Connected LaunchPadв„ў for IoT Applications
  • Evaluation Modules & Boards: BOOST-CC2564MODA
    Dual-mode BluetoothВ® CC2564 module with integrated antenna BoosterPackВ™ plug-in module
  • CC256XQFN PCB Guidelines (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 28 окт 2016
  • Using TI Technology to Simplify Bluetooth Pairing Via NFC
    PDF, 3.0 Мб, Файл опубликован: 28 ноя 2011
    Bluetooth pairing usually involves some level of user interaction to confirm the identity of the user and/or the devices themselves. There are many pairing mechanisms available across the versions of Bluetooth (v2.0 through v4.0). This process is typically lengthy and sometimes confusing to the user, and so this application report is aimed at showing TI technology developers details on implementin
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
  • Semiconductors > Wireless Connectivity > Dual Mode Bluetooth (BLE/BT) > CC2564
На английском языке: Datasheet Texas Instruments CC2564BRVMR
