Datasheet Texas Instruments CC2564MODNCMOER — Даташит
СерияCC2564MODN
МодельCC2564MODNCMOER
Двухрежимный модуль Bluetooth® CC2564 33-QFM от -30 до 85
CC2564MODx BluetoothВ® Host Controller Interface (HCI) Module datasheet
PDF, 16.9 Мб, Версия: E, Файл опубликован: 16 янв 2016
Pin33
Package TypeMOE
Package QTY2000
Width (мм)7
Length (мм)7
Thickness (мм)1.4
Bluetooth StandardBluetooth Smart (Bluetooth low energy),Classic Bluetooth,Dual-mode Bluetooth
Data Rate(Max)3000 kbps
Device TypeSmart RF Transceiver,Module
Package GroupQFM
Package Size: mm2:W x LSee datasheet (QFM) PKG
Special FeaturesN/A
TechnologyDual-mode Bluetooth
Throughput(Max)3 Mbps
RoHSНе совместим
  • Evaluation Modules & Boards: DLPNIRNANOEVM
    DLPВ® NIRscanВ™ Nano Evaluation Module
  • Evaluation Modules & Boards: CC256XSTBTBLESW
    TI Dual-mode BluetoothВ® Stack on STM32F4 MCUs
  • Evaluation Modules & Boards: MSP-EXP430F5529
    MSP430F5529 USB Experimenter’s Board
  • Evaluation Modules & Boards: BT-MSPAUDSOURCE
    Bluetooth and MSP430 Audio Source Reference Design Board
  • Evaluation Modules & Boards: CC2564MODNEM
    Dual-mode BluetoothВ® CC2564 module evaluation board
  • Evaluation Modules & Boards: CC256XQFNEM
    Dual-mode BluetoothВ® CC2564 evaluation board
  • Evaluation Modules & Boards: MSP-EXP430F5438
    MSP430F5438 Experimenter Board
  • Development Kits: DK-TM4C123G
    TM4C123G USB+CAN Development Kit
  • Evaluation Modules & Boards: CC2564MODAEM
    Dual-mode BluetoothВ® CC2564 Module with Integrated Antenna Evaluation Board
  • Evaluation Modules & Boards: BOOST-CC2564MODA
    Dual-mode BluetoothВ® CC2564 module with integrated antenna BoosterPackВ™ plug-in module
  • Development Kits: DK-TM4C129X
    IoT Enabled ARMВ® CortexВ®-M4F MCU TM4C129X Connected Development Kit
  • Using TI Technology to Simplify Bluetooth Pairing Via NFC
    PDF, 3.0 Мб, Файл опубликован: 28 ноя 2011
    Bluetooth pairing usually involves some level of user interaction to confirm the identity of the user and/or the devices themselves. There are many pairing mechanisms available across the versions of Bluetooth (v2.0 through v4.0). This process is typically lengthy and sometimes confusing to the user, and so this application report is aimed at showing TI technology developers details on implementin
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
Серия: CC2564MODN (2)
  • Semiconductors > Wireless Connectivity > Dual Mode Bluetooth (BLE/BT) > CC2564
На английском языке: Datasheet Texas Instruments CC2564MODNCMOER
