Datasheet Texas Instruments CC2591RGVR — Даташит
СерияCC2591
МодельCC2591RGVR
Расширитель диапазона 2,4 ГГц 16-VQFN от -40 до 85
CC2591 2.4-GHz RF Front End datasheet
PDF, 984 Кб, Версия: B, Файл опубликован: 3 сен 2014
Pin16
Package TypeRGV
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаCC2591
Width (мм)4
Length (мм)4
Thickness (мм).9
Max Height (мм)1
  • Daughter Cards: CC2520EMK
    CC2520 Evaluation Module Kit
  • AN065: Using CC2591 RF Front End with CC2520 (Rev. A)
    PDF, 369 Кб, Версия: A, Файл опубликован: 8 янв 2010
    This application note is targeted designers of RF systems with CC2520 and the CC2591 RF Power Amplifier (PA). It describes how to implement the CC2520 and the CC2591 in the same design. It further describes the expected performance from this combination as well as important factors to consider with respect to the layout and regulatory requirements. The combined CC2520 and CC2591 solution is suitab
  • AN066: TI-MAC modifications for using CC2591 PA/LNA with MSP430F2618+CC2520 (Rev. A)
    PDF, 87 Кб, Версия: A, Файл опубликован: 13 окт 2008
  • AN063: Using CC2591 RF Front End with CC2430
    PDF, 209 Кб, Файл опубликован: 15 июл 2008
  • AN062: TI-MAC and Z-Stack modifications for using CC2591 RF Front End w/CC2430 (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 сен 2008
  • AN078 -- TIMAC and Z-Stack Modifications for using CC2591 RF Front End with CC2
    PDF, 216 Кб, Файл опубликован: 9 ноя 2009
    This application note describes how to modify the TI-MAC (v1.3.0) / Z-Stack (v2.2.0) software releases for the CC2530 SoC to support CC2591 PA/LNA controls.
  • AN086 -- Using CC2591 Front End with CC2530 and CC2531 (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 16 дек 2009
    This application note is targeted designers of RF systems with CC2530/CC2531 and the CC2591 RF Power Amplifier (PA). It describes how to implement the CC2530 and the CC2591 in the same design. It further describes the expected performance from this combination as well as important factors to consider with respect to the layout and regulatory requirements. The combined CC2530 and CC2591 soluti
  • AN068 - Design Steps and Results for Changing PCB Layer Thickness (Rev. A)
    PDF, 792 Кб, Версия: A, Файл опубликован: 8 окт 2009
  • DN034 -- YAGI 2.4 GHz PCB Antenna
    PDF, 1.9 Мб, Файл опубликован: 14 окт 2010
  • DN000 - Design Note Overview (Rev. T)
    PDF, 126 Кб, Версия: T, Файл опубликован: 12 окт 2011
  • DN031 -- CC-Antenna-DK Documentation and Antenna Measurements Summary
    PDF, 2.3 Мб, Файл опубликован: 26 авг 2010
    DN031 -- Design Notes
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
  • Semiconductors > Wireless Connectivity > Companion Wireless Solutions > Range Extenders
На английском языке: Datasheet Texas Instruments CC2591RGVR
