Datasheet Texas Instruments CC2592RGVR — Даташит
СерияCC2592
МодельCC2592RGVR
Расширитель диапазона 2,4 ГГц 16-VQFN от -40 до 125
CC2592 2.4-GHz Range Extender datasheet
PDF, 921 Кб, Файл опубликован: 25 фев 2014
Pin16
Package TypeRGV
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаCC2592
Width (мм)4
Length (мм)4
Thickness (мм).9
Max Height (мм)1
ADCN/A
Data Rate(Max)500,2000 kbps
Device TypeRange Extender
Тактовая частота2400 МГц
Выходная мощность22 dBm
Over-the-air UpgradeNo
PA Efficiency35 %
Package GroupVQFN
ПериферияN/A
Processor IntegrationN/A
RX Current (Lowest)1.9 мА
RX SensitivityTypical 3 dB improvement dBm
SecurityN/A
Sleep Current0.1 uA
Technology2.4 GHz
Throughput(Max)N/A Mbps
Type of BatteryN/A
  • Development Kits: CC-ANTENNA-DK2
    Sub-1 GHz and 2.4 GHz Antenna Kit for LaunchPadВ™ and SensorTag
  • Daughter Cards: CC2538-CC2592EMK
    CC2538-CC2592 Evaluation Module Kit
  • AN130 - Using CC2592 Front End with CC2538
    PDF, 418 Кб, Файл опубликован: 27 фев 2014
    This application report describes how to implement the CC2538 and the CC2592 in the same design. It further describes the expected performance from this combination as well as important factors to consider with respect to the layout and regulatory requirements. The combined CC2538 and CC2592 solution is suitable for systems targeting compliance with FCC CFR47 Part 15.
  • Using CC2592 Front End with CC2530 (Rev. A)
    PDF, 541 Кб, Версия: A, Файл опубликован: 29 июл 2015
    This application report describes the pairing of the cost-effective SimpleLinkв„ў ZigBee CC2530 wireless MCU with the SimpleLink CC2592 range extender to improve the receiver sensitivity and increase the total link budget, enabling up to four times the range of each node in the ZigBee network. The combination of these devices creates a system solution that is ideal for applications such as hom
Серия: CC2592 (2)
  • Semiconductors > Wireless Connectivity > 6LoWPAN
На английском языке: Datasheet Texas Instruments CC2592RGVR
