Datasheet Texas Instruments CC8520 — Даташит
СерияCC8520
PurePathв„ў Wireless 2.4 GHz RF SoC for wireless digital audio streaming
2.4 GHz RF SoC For Wireless Digital Audio Streaming datasheet
PDF, 991 Кб, Версия: F, Файл опубликован: 2 июл 2012
CC8520RHARCC8520RHAT
Доступность образцов у производителяДаНет
N12
Pin4040
Package TypeRHARHA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY2500250
CarrierLARGE T&RSMALL T&R
МаркировкаCC8520CC8520
Width (мм)66
Length (мм)66
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Parameters / ModelsCC8520RHAR
CC8520RHAR
CC8520RHAT
CC8520RHAT
Data Rate(Max), kbps50005000
Device TypeProtocol ProcessorProtocol Processor
Flash, KBN/AN/A
Key Software FeaturesBuilt In audio Protocol,Adaptive Frequency Hoping,High Quality Audio CompressionBuilt In audio Protocol,Adaptive Frequency Hoping,High Quality Audio Compression
Max VCC3.63.6
Min VCC22
Modulation Techniques8FSK,2FSK8FSK,2FSK
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
RAM size, KBN/AN/A
RX Current (Lowest), мАN/AN/A
RatingCatalogCatalog
Sensitivity (Best), dBm-86-86
TX Power(Max), dBm3.53.5
TechnologyPurePath Wireless AudioPurePath Wireless Audio
Throughput(Max), MbpsN/AN/A
USB 2.0NoNo
RoHSСовместимСовместим
  • AN089 -- Real World Range Testing Using CC85xx
    PDF, 1.4 Мб, Файл опубликован: 29 июн 2010
  • DN120 -- CC85XX External Host Interface: Eamples and Library (Rev. A)
    PDF, 274 Кб, Версия: A, Файл опубликован: 7 авг 2012
    The CC85xx EHIF Library implements a generic framework for using the External Host Interface (EHIF), based on a 4-wire SPI interface and 2 optional GPIO pins. This allowsexternal microcontroller or DSP, also referred to as the host processor, to implement flash programming and production tests, operate the CC85xx in host-controlled operation and check performance in autonomous operation:
  • Adaptive Frequency Hopping and Other Co-Existence Mechanisms for CC85xx
    PDF, 149 Кб, Файл опубликован: 16 июл 2015
    This application report provides operational details of the RF System that are used in the PurePath Wireless family of devices (CC85xx).
  • 2.4 GHz Bi-directional Audio Streaming with Karaoke for DVDs and Set Top Boxes
    PDF, 2.4 Мб, Файл опубликован: 7 ноя 2013
    CC8531 ,TLV320AIC3204 2.4 GHz Bi-directional Audio Streaming with Karaoke for DVDs and Set Top Boxes
  • AN107 - Murata Balun for CC253x and CC254x, LFB182G45BG2D280 (Rev. A)
    PDF, 805 Кб, Версия: A, Файл опубликован: 26 окт 2011
  • AN081 -- Johanson Technology Balun Optimized for CC253X, CC254X, CC257X, CC853X (Rev. B)
    PDF, 456 Кб, Версия: B, Файл опубликован: 6 ноя 2012
  • DN034 -- YAGI 2.4 GHz PCB Antenna
    PDF, 1.9 Мб, Файл опубликован: 14 окт 2010
  • DN000 - Design Note Overview (Rev. T)
    PDF, 126 Кб, Версия: T, Файл опубликован: 12 окт 2011
  • DN031 -- CC-Antenna-DK Documentation and Antenna Measurements Summary
    PDF, 2.3 Мб, Файл опубликован: 26 авг 2010
    DN031 -- Design Notes
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
Серия: CC8520 (2)
  • Semiconductors> Wireless Connectivity> Proprietary 2.4 GHz
На английском языке: Datasheet Texas Instruments CC8520
