Datasheet Texas Instruments CC8521RHAR — Даташит
СерияCC8521
МодельCC8521RHAR
PurePath™ Wireless 2,4 ГГц RF SoC для беспроводной потоковой передачи цифрового аудио 40-VQFN от -40 до 85
2.4 GHz RF SoC For Wireless Digital Audio Streaming datasheet
PDF, 991 Кб, Версия: F, Файл опубликован: 2 июл 2012
Радиочастотная деталь RF, PurePathTM Wireless 2.4GHz RF SoC for wireless digital audio streaming 40-VQFN -40℃ to 85℃
Триема
CC8521RHAR
332 ₽
CC8521RHAR
507 ₽
CC8521RHAR
507 ₽
CC8521RHAR
Pin40
Package TypeRHA
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаCC8521
Width (мм)6
Length (мм)6
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Data Rate(Max)5000 kbps
Device TypeProtocol Processor
FlashN/A KB
Key Software FeaturesBuilt In audio Protocol,Adaptive Frequency Hoping,High Quality Audio Compression
Max VCC3.6
Min VCC2
Modulation Techniques8FSK,2FSK
RAM sizeN/A KB
RX Current (Lowest)See data sheet мА
Sensitivity (Best)-86 dBm
TX Power(Max)3.5 dBm
TechnologyPurePath Wireless Audio
Throughput(Max)N/A Mbps
USB 2.0Yes
  • Evaluation Modules & Boards: CC85XXDK-HEADSET
    PurePath Wireless Headset Development Kit
  • Development Kits: CC85XXDK
    PurePath Wireless Development Kit
  • DN120 -- CC85XX External Host Interface: Eamples and Library (Rev. A)
    PDF, 274 Кб, Версия: A, Файл опубликован: 7 авг 2012
    The CC85xx EHIF Library implements a generic framework for using the External Host Interface (EHIF), based on a 4-wire SPI interface and 2 optional GPIO pins. This allowsexternal microcontroller or DSP, also referred to as the host processor, to implement flash programming and production tests, operate the CC85xx in host-controlled operation and check performance in autonomous operation:
  • Adaptive Frequency Hopping and Other Co-Existence Mechanisms for CC85xx
    PDF, 149 Кб, Файл опубликован: 16 июл 2015
    This application report provides operational details of the RF System that are used in the PurePath Wireless family of devices (CC85xx).
  • 2.4 GHz Bi-directional Audio Streaming with Karaoke for DVDs and Set Top Boxes
    PDF, 2.4 Мб, Файл опубликован: 7 ноя 2013
    CC8531 ,TLV320AIC3204 2.4 GHz Bi-directional Audio Streaming with Karaoke for DVDs and Set Top Boxes
  • AN107 - Murata Balun for CC253x and CC254x, LFB182G45BG2D280 (Rev. A)
    PDF, 805 Кб, Версия: A, Файл опубликован: 26 окт 2011
  • AN081 -- Johanson Technology Balun Optimized for CC253X, CC254X, CC257X, CC853X (Rev. B)
    PDF, 456 Кб, Версия: B, Файл опубликован: 6 ноя 2012
Серия: CC8521 (2)
  • Semiconductors > Wireless Connectivity > Proprietary 2.4 GHz
На английском языке: Datasheet Texas Instruments CC8521RHAR
