Datasheet Texas Instruments CC8531 — Даташит
СерияCC8531
PurePathв„ў Wireless 2.4 GHz RF SoC for wireless digital audio streaming
2.4 GHz RF SoC For Wireless Digital Audio Streaming datasheet
PDF, 991 Кб, Версия: F, Файл опубликован: 2 июл 2012
33 предложений от 20 поставщиков
Радиочастотная деталь RF, PurePathTM Wireless 2.4GHz RF SoC for wireless digital audio streaming 40-VQFN -40℃ to 85℃
CC8531RHAR
65 ₽
CC8531RHAT
от 1 209 ₽
CC8531RHAT
TradeElectronics
CC8531RHAT
CC8531RHARCC8531RHAT
Доступность образцов у производителяНетДа
N12
Pin4040
Package TypeRHARHA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY2500250
CarrierLARGE T&RSMALL T&R
МаркировкаCC8531CC8531
Width (мм)66
Length (мм)66
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Parameters / ModelsCC8531RHAR
CC8531RHAR
CC8531RHAT
CC8531RHAT
Data Rate(Max), kbps50005000
Device TypeProtocol ProcessorProtocol Processor
Flash, KBN/AN/A
Key Software FeaturesBuilt In audio Protocol,Adaptive Frequency Hoping,High Quality Audio CompressionBuilt In audio Protocol,Adaptive Frequency Hoping,High Quality Audio Compression
Max VCC3.63.6
Min VCC22
Modulation Techniques8FSK,2FSK8FSK,2FSK
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
RAM size, KBN/AN/A
RX Current (Lowest), мАSee data sheetSee data sheet
RatingCatalogCatalog
Sensitivity (Best), dBm-86-86
TX Power(Max), dBm3.53.5
TechnologyPurePath Wireless AudioPurePath Wireless Audio
Throughput(Max), MbpsN/AN/A
USB 2.0YesYes
RoHSСовместимСовместим
  • DN120 -- CC85XX External Host Interface: Eamples and Library (Rev. A)
    PDF, 274 Кб, Версия: A, Файл опубликован: 7 авг 2012
    The CC85xx EHIF Library implements a generic framework for using the External Host Interface (EHIF), based on a 4-wire SPI interface and 2 optional GPIO pins. This allowsexternal microcontroller or DSP, also referred to as the host processor, to implement flash programming and production tests, operate the CC85xx in host-controlled operation and check performance in autonomous operation:
  • Adaptive Frequency Hopping and Other Co-Existence Mechanisms for CC85xx
    PDF, 149 Кб, Файл опубликован: 16 июл 2015
    This application report provides operational details of the RF System that are used in the PurePath Wireless family of devices (CC85xx).
  • 2.4 GHz Bi-directional Audio Streaming with Karaoke for DVDs and Set Top Boxes
    PDF, 2.4 Мб, Файл опубликован: 7 ноя 2013
    CC8531 ,TLV320AIC3204 2.4 GHz Bi-directional Audio Streaming with Karaoke for DVDs and Set Top Boxes
  • AN107 - Murata Balun for CC253x and CC254x, LFB182G45BG2D280 (Rev. A)
    PDF, 805 Кб, Версия: A, Файл опубликован: 26 окт 2011
  • AN081 -- Johanson Technology Balun Optimized for CC253X, CC254X, CC257X, CC853X (Rev. B)
    PDF, 456 Кб, Версия: B, Файл опубликован: 6 ноя 2012
Серия: CC8531 (2)
  • Semiconductors> Wireless Connectivity> Proprietary 2.4 GHz
На английском языке: Datasheet Texas Instruments CC8531
