Datasheet ТI CD54AC04 — Даташит
| Серия | CD54AC04 |
Шестигранные инверторы
Hex Inverters datasheet
PDF, 980 Кб, Версия: C, Файл опубликован: 12 июн 2002
| CD54AC04F3A | |
| CD54AC04F3A | |
| N | 1 |
| Pin | 14 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | CD54AC04F3A |
| Width (мм) | 6.67 |
| Length (мм) | 19.56 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Parameters / Models | CD54AC04F3A![]() |
| Bits | 8 |
| Тип входа | CMOS |
| Рабочий диапазон температур, C | от -55 до 125 |
| Тип выхода | CMOS |
| Package Group | CDIP |
| Package Size: mm2:W x L, PKG | See datasheet (CDIP) |
| Rating | Military |
| Schmitt Trigger | No |
| Technology Family | AC |
| VCC(Max), В | 5.5 |
| VCC(Min), В | 1.5 |
| Voltage(Nom), В | 1.5,3.3,5 |
| CD54AC04F3A | |
| RoHS | See ti.com |
- Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD54AC04 (1)
- Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Buffer Drivers
