Datasheet Texas Instruments CD54AC157 — Даташит
| Серия | CD54AC157 |
Счетверенные неинвертирующие мультиплексоры с 2 входами
QUAD 2-INPUT MULTIPLEXERS | |||
| CD54AC157 Texas Instruments | по запросу | ||
| CD54AC157F3A | |
| CD54AC157F3A | |
| N | 1 |
| Pin | 16 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | CD54AC157F3A |
| Width (мм) | 6.92 |
| Length (мм) | 19.56 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Parameters / Models | CD54AC157F3A![]() |
| Количество каналов | 4 |
| F @ Nom Voltage(Max), Mhz | 100 |
| ICC @ Nom Voltage(Max), мА | 0.08 |
| Рабочий диапазон температур, C | от -55 до 125 |
| Package Group | CDIP |
| Package Size: mm2:W x L, PKG | See datasheet (CDIP) |
| Rating | Military |
| Schmitt Trigger | No |
| Technology Family | AC |
| VCC(Max), В | 5.5 |
| VCC(Min), В | 1.5 |
| Voltage(Nom), В | 1.5,3.3,5 |
| tpd @ Nom Voltage(Max), нс | 97,10.8,7.7 |
| CD54AC157F3A | |
| RoHS | See ti.com |
- Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD54AC157 (1)
- Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Decoders/Encoders/Multiplexers
