Datasheet Texas Instruments CD54AC373F3A — Даташит
| Серия | CD54AC373 |
| Модель | CD54AC373F3A |
Восьмеричные прозрачные защелки с выходами с 3 состояниями 20-CDIP от -55 до 125
Octal Transparent Latch, 3-State datasheet
PDF, 1.3 Мб, Файл опубликован: 3 дек 1998
Купить CD54AC373F3A на РадиоЛоцман.Цены — от 370 до 4 434 ₽16 предложений от 16 поставщиков Микросхема Логический замок, Latch Transparent 3-ST 8CH D-Type 20Pin CDIP Tube | |||
| CD54AC373F3A Harris | 370 ₽ | ||
| CD54AC373F3A Harris | 4 126 ₽ | ||
| CD54AC373F3A Harris | 4 434 ₽ | ||
| CD54AC373F3A Harris | по запросу | ||
| Pin | 20 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | CD54AC373F3A |
| Width (мм) | 6.92 |
| Length (мм) | 24.2 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| 3-State Output | Yes |
| Bits | 8 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.08 мА |
| Тип входа | CMOS |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | 24/-24 мА |
| Тип выхода | CMOS |
| Package Group | CDIP |
| Package Size: mm2:W x L | See datasheet (CDIP) PKG |
| Rating | Military |
| Technology Family | AC |
| VCC(Max) | 5.5 В |
| VCC(Min) | 1.5 В |
| tpd @ Nom Voltage(Max) | 96,10.8,7.7 нс |
| RoHS | See ti.com |
- CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD54AC373 (1)
- CD54AC373F3A
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
