Datasheet Texas Instruments CD54ACT373 — Даташит
| Серия | CD54ACT373 |
Восьмеричные прозрачные защелки с выходами с 3 состояниями
Octal Transparent Latch, 3-State datasheet
PDF, 1.3 Мб, Файл опубликован: 3 дек 1998
OCTAL TRANSPARENT LATCH, 3-STATE | |||
| CD54ACT373 Texas Instruments | по запросу | ||
| CD54ACT373F3A | |
| CD54ACT373F3A | |
| N | 1 |
| Pin | 20 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | CD54ACT373F3A |
| Width (мм) | 6.92 |
| Length (мм) | 24.2 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Parameters / Models | CD54ACT373F3A![]() |
| 3-State Output | Yes |
| Bits | 8 |
| F @ Nom Voltage(Max), Mhz | 90 |
| ICC @ Nom Voltage(Max), мА | 0.04 |
| Тип входа | TTL |
| Рабочий диапазон температур, C | от -55 до 125 |
| Output Drive (IOL/IOH)(Max), мА | 24/-24 |
| Тип выхода | CMOS |
| Package Group | CDIP |
| Package Size: mm2:W x L, PKG | See datasheet (CDIP) |
| Rating | Military |
| Technology Family | ACT |
| VCC(Max), В | 5.5 |
| VCC(Min), В | 4.5 |
| tpd @ Nom Voltage(Max), нс | 11.5 |
| CD54ACT373F3A | |
| RoHS | See ti.com |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD54ACT373 (1)
- Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
