Datasheet ТI CD54HC280 — Даташит
СерияCD54HC280
Datasheet Texas Instruments CD54HC280
Высокоскоростной 9-битный генератор четности/нечетности с CMOS-логикой/контроллер
CD54HC280, CD74HC280, CD54HCT280, CD74HCT280 datasheet
PDF, 708 Кб, Версия: D, Файл опубликован: 21 окт 2003
8607701CACD54HC280F3A
N12
Pin1414
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаCD54HC280F3ACD54HC280F3A
Width (мм)6.676.67
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Parameters / Models8607701CA
8607701CA
CD54HC280F3A
CD54HC280F3A
Bits22
F @ Nom Voltage(Max), Mhz2828
FunctionParityParity
ICC @ Nom Voltage(Max), мА0.080.08
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА5.2/-5.25.2/-5.2
Package GroupCDIPCDIP
Package Size: mm2:W x L, PKGSee datasheet (CDIP)See datasheet (CDIP)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyHCHC
ТипOtherOther
VCC(Max), В66
VCC(Min), В22
Voltage(Nom), В3.3,53.3,5
tpd @ Nom Voltage(Max), нс4343
RoHSSee ti.comSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC280 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments CD54HC280
Политика конфиденциальности
