Datasheet ТI CD54HC393 — Даташит
| Серия | CD54HC393 |
Высокоскоростной двойной 4-ступенчатый двоичный счетчик с CMOS-логикой
CD54HC393, CD74HC393, CD54HCT393, CD74HCT393 datasheet
PDF, 718 Кб, Версия: E, Файл опубликован: 21 авг 2003
| CD54HC393F3A | |
| CD54HC393F3A | |
| N | 1 |
| Pin | 14 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | 8410001CA |
| Width (мм) | 6.67 |
| Length (мм) | 19.56 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Parameters / Models | CD54HC393F3A![]() |
| Bits | 4 |
| F @ Nom Voltage(Max), Mhz | 28 |
| Function | Counter |
| ICC @ Nom Voltage(Max), мА | 0.08 |
| Рабочий диапазон температур, C | от -55 до 125 |
| Output Drive (IOL/IOH)(Max), мА | 5.2/-5.2 |
| Package Group | CDIP |
| Package Size: mm2:W x L, PKG | See datasheet (CDIP) |
| Rating | Military |
| Schmitt Trigger | No |
| Technology Family | HC |
| Тип | Binary |
| VCC(Max), В | 6 |
| VCC(Min), В | 2 |
| Voltage(Nom), В | 3.3,5 |
| tpd @ Nom Voltage(Max), нс | 60 |
| CD54HC393F3A | |
| RoHS | See ti.com |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HC393 (1)
- Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Counter/Arithmetic/Parity Function Products
