Datasheet Texas Instruments CD54HC40105 — Даташит
СерияCD54HC40105
Высокоскоростная логика КМОП, 4 бита, 16-словный регистр FIFO
CD54HC40105, CD74HC40105, CD54HCT40105, CD74HCT40105 datasheet
PDF, 867 Кб, Версия: C, Файл опубликован: 16 окт 2003
CD54HC40105F3A
Статус продуктаВ производстве
CD54HC40105F3A
N1
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаCD54HC40105F3A
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
CD54HC40105F3A
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC40105 (1)
  • Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments CD54HC40105
