Datasheet Texas Instruments CD54HC4040 — Даташит
СерияCD54HC4040
Высокоскоростной 12-ступенчатый двоичный счетчик КМОП-логики
CD54HC4040, CD74HC4040, CD54HCT4040, CD74HCT4040 datasheet
PDF, 462 Кб, Версия: D, Файл опубликован: 16 окт 2003
CD54HC4040FCD54HC4040F3A
N12
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаCD54HC4040FCD54HC4040F3A
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Parameters / ModelsCD54HC4040F
CD54HC4040F
CD54HC4040F3A
CD54HC4040F3A
Bits1212
F @ Nom Voltage(Max), Mhz2828
FunctionCounterCounter
ICC @ Nom Voltage(Max), мА0.080.08
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА5.2/-5.25.2/-5.2
Package GroupCDIPCDIP
Package Size: mm2:W x L, PKGSee datasheet (CDIP)See datasheet (CDIP)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyHCHC
ТипBinaryBinary
VCC(Max), В66
VCC(Min), В22
Voltage(Nom), В3.3,53.3,5
tpd @ Nom Voltage(Max), нс3030
RoHSSee ti.comSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC4040 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments CD54HC4040
