Datasheet Texas Instruments CD54HC4514 — Даташит
СерияCD54HC4514
Высокоскоростной КМОП-логический декодер/демультиплексор строк от 4 до 16 с входными защелками
CD54HC4514, CD74HC4514, CD74HC4515 datasheet
PDF, 448 Кб, Версия: C, Файл опубликован: 20 июн 2003
5962-9865501QJACD54HC4514F3A
N12
Pin2424
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-CDIP-TR-CDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаCD54HC4514F3A5962-9865501QJ
Width (мм)13.413.4
Length (мм)31.7531.75
Thickness (мм)44
Pitch (мм)2.542.54
Max Height (мм)4.914.91
Parameters / Models5962-9865501QJA
5962-9865501QJA
CD54HC4514F3A
CD54HC4514F3A
Количество каналов11
F @ Nom Voltage(Max), Mhz2828
ICC @ Nom Voltage(Max), мА0.080.08
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Package GroupCDIPCDIP
Package Size: mm2:W x L, PKGSee datasheet (CDIP)See datasheet (CDIP)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyHCHC
VCC(Max), В66
VCC(Min), В22
Voltage(Nom), В3.3,53.3,5
tpd @ Nom Voltage(Max), нс2323
RoHSSee ti.comSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Live Insertion
  • Introduction to Logic
Серия: CD54HC4514 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Decoders/Encoders/Multiplexers
На английском языке: Datasheet Texas Instruments CD54HC4514
