Datasheet ТI CD54HCT163 — Даташит
| Серия | CD54HCT163 |
Высокоскоростной 4-битный двоичный счетчик КМОП-логики с синхронным сбросом
CD54/74HC161, CD54/74HCT161, CD54/74HC163, CD54/74HCT163 datasheet
PDF, 469 Кб, Версия: D, Файл опубликован: 13 окт 2003
| CD54HCT163F | CD54HCT163F3A | |
| Статус продукта | В производстве | В производстве |
| Доступность образцов у производителя | Нет | Нет |
| N | 1 | 2 |
| Pin | 16 | 16 |
| Package Type | J | J |
| Industry STD Term | CDIP | CDIP |
| JEDEC Code | R-GDIP-T | R-GDIP-T |
| Package QTY | 1 | 1 |
| Carrier | TUBE | TUBE |
| Маркировка | CD54HCT163F | CD54HCT163F3A |
| Width (мм) | 6.92 | 6.92 |
| Length (мм) | 19.56 | 19.56 |
| Thickness (мм) | 4.57 | 4.57 |
| Pitch (мм) | 2.54 | 2.54 |
| Max Height (мм) | 5.08 | 5.08 |
| Parameters / Models | CD54HCT163F![]() | CD54HCT163F3A![]() |
| Bits | 4 | 4 |
| F @ Nom Voltage(Max), Mhz | 25 | 25 |
| Function | Counter | Counter |
| ICC @ Nom Voltage(Max), мА | 0.08 | 0.08 |
| Рабочий диапазон температур, C | от -55 до 125 | от -55 до 125 |
| Output Drive (IOL/IOH)(Max), мА | 4/-4 | 4/-4 |
| Package Group | CDIP | CDIP |
| Package Size: mm2:W x L, PKG | See datasheet (CDIP) | See datasheet (CDIP) |
| Rating | Military | Military |
| Schmitt Trigger | No | No |
| Technology Family | HCT | HCT |
| Тип | Binary | Binary |
| VCC(Max), В | 5.5 | 5.5 |
| VCC(Min), В | 4.5 | 4.5 |
| Voltage(Nom), В | 5 | 5 |
| tpd @ Nom Voltage(Max), нс | 49 | 49 |
| RoHS | See ti.com | See ti.com |
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HCT163 (2)
- Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Counter/Arithmetic/Parity Function Products
