Datasheet ТI 5962-8685601RA — Даташит
| Серия | CD54HCT573 |
| Модель | 5962-8685601RA |
Высокоскоростная КМОП-логика, восьмеричная прозрачная защелка с выходом с 3 состояниями, 20-CDIP, от -55 до 125
CD54HCT573, CD74HCT573 datasheet
PDF, 918 Кб, Версия: C, Файл опубликован: 17 май 2004
- Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
The TI SN54/74HCT family of CMOS devices is a subgroup of the SN74HC series with the HCT circuitry modified to meet the interfacing requirements of TTL outputs to high-speed CMOS inputs. The HCT devices can be driven by the TTL circuits directly without additional components. This document describes the TTL/HC interface the operating voltages circuit noise and power consumption. A Bergeron anal - Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Implications of Slow or Floating CMOS Inputs (Rev. D)PDF, 260 Кб, Версия: D, Файл опубликован: 23 июн 2016
- TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
Серия: CD54HCT573 (3)
- 5962-8685601RA CD54HCT573F CD54HCT573F3A
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
59628685601RA, 5962 8685601RA
