Datasheet Texas Instruments CDC2510PWRG4 — Даташит
СерияCDC2510
МодельCDC2510PWRG4
Драйвер тактового сигнала с фазовой автоподстройкой напряжения 3,3 В 24-TSSOP
CDC2510: 3.3-V Phase-Lock Loop Clock Driver datasheet
PDF, 608 Кб, Версия: B, Файл опубликован: 2 дек 2004
Микросхема Тактовый генератор, PLL Clock Driver Single 25MHz to 125MHz 24Pin TSSOP T/R
CDC2510PWRG4
960 ₽
CDC2510PWRG4
960 ₽
CDC2510PWRG4
CDC2510PWRG4
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаCK2510
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
  • Understanding the Differences Between CDC2509x/10x Devices
    PDF, 65 Кб, Файл опубликован: 8 янв 1999
    This application note provides information concerning the various revisions of the TI CDC2509/10 family of devices. In addition, it will assist designers with new and existing designs. Phase error information, both slope and absolute value, is provided to assist in the tuning process. Furthermore, a table summarizes important parameters for choosing the correct PLL. The table contains capacitance
  • High Speed Clock Distribution Design Techniques for CDC 509/516/2509/2510/2516 (Rev. A)
    PDF, 109 Кб, Версия: A, Файл опубликован: 23 сен 1998
    The memory bandwidth of high performance microprocessors is increasing at a rapid rate and the future memory bandwidth requirements are expected to keep increasing. The bandwidth requirements of RAM will be satisfied in the near term by using Synchronous DRAM. The need to drive multiple DRAM chips at high speeds with low skew necessitates the use of clock distribution devices with Phase Locked Loo
Серия: CDC2510 (2)
  • Semiconductors > Clock and Timing > Clock Buffers > Zero Delay Buffers
На английском языке: Datasheet Texas Instruments CDC2510PWRG4
