Datasheet Texas Instruments CDC2582PAHG4 — Даташит
СерияCDC2582
МодельCDC2582PAHG4
Драйвер тактового сигнала ФАПЧ 3,3 В с входом LVPECL и 12 выходами LVTTL 52-TQFP
3.3-V Phase-Lock Loop Clock Driver With Differential LVPECL Clock Inputs datasheet
PDF, 150 Кб, Версия: B, Файл опубликован: 1 фев 1996
Микросхема Тактовый генератор, PLL Clock Driver Single 25MHz to 100MHz 52Pin TQFP Tray
CDC2582PAHG4
525 ₽
Hi-Tech Circuit Group
CDC2582PAHG4
CDC2582PAHG4
CDC2582PAHG4
Pin52
Package TypePAH
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY160
CarrierJEDEC TRAY (10+1)
МаркировкаCDC2582
Width (мм)10
Length (мм)10
Thickness (мм)1
Max Height (мм)1.2
Absolute Jitter (Peak-to-Peak Cycle or Period Jitter)200 ps
Количество выходов12
Operating Frequency Range(Max)100 МГц
Operating Frequency Range(Min)25 МГц
Package GroupTQFP
Package Size: mm2:W x L52TQFP: 144 mm2: 12 x 12(TQFP) PKG
VCC3.3 В
t(phase error)500 ps
tsk(o)500 ps
  • Phase-Lock Loop-Based (PLL) Clock Drivers: Benefits Versus Costs (Rev. A)
    PDF, 51 Кб, Версия: A, Файл опубликован: 1 мар 1997
    This document provides an overview of a PLL clock driver. The advantages and disadvantages of PLLs and the cost in designs are discussed. TI manufactures three low-voltage high-performance PLL clock drivers, the CDC2582, CDC2586, and the CDC2586.
  • Application and Design Considerations for CDC5xx Phase-Lock Loop Clock Drivers
    PDF, 101 Кб, Файл опубликован: 1 апр 1996
    Today?s high-speed system designs require stringent propagation and skew parameters to maintain desired system performance. TI developed the CDC5XX platform of PLL clock drivers to meet the need for high-performance clock system components. This document describes the features and functions of the CDC5XX and discusses design considerations and configurations for the CDC586, CDC582, and CDC2582 clo
Серия: CDC2582 (2)
  • Semiconductors > Clock and Timing > Clock Buffers > Zero Delay Buffers
На английском языке: Datasheet Texas Instruments CDC2582PAHG4
