Datasheet Texas Instruments CDC906PW — Даташит
СерияCDC906
МодельCDC906PW
Программируемый тактовый синтезатор с 3 схемами ФАПЧ/умножитель/делитель 20-TSSOP
Programmable 3-PLL Clock Synthesizer / Multiplier / Divider datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 11 фев 2008
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY70
МаркировкаCDC906
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
  • CDCx706/x906 Termination and Signal Integrity Guidelines (Rev. A)
    PDF, 155 Кб, Версия: A, Файл опубликован: 28 ноя 2007
    This application report shows and evaluates different schemes for the CDCE706, CDCE906, CDC706, and CDC906. Guidelines for optimizing the series termination are discussed. Additionally, this report describes how the CDCx706/x906 family can be used to drive 1.8-V clock inputs.
  • High Speed Layout Guidelines (Rev. A)
    PDF, 762 Кб, Версия: A, Файл опубликован: 8 авг 2017
    Thisapplicationreportaddresseshigh-speedsignals,suchas clocksignalsand theirrouting,and givesdesignersa reviewof the importantcoherences.Withsomesimplerules,electromagneticinterferenceproblemscan be minimizedwithoutusingcomplicatedformulasand expensivesimulationtools.Section1givesa shortintroductionto theory,whileSection
  • Clock Recommendations for the DM643x EVM
    PDF, 121 Кб, Файл опубликован: 29 ноя 2006
    The DM643x evaluation module (EVM) requires several clock frequencies to run the system properly. The current clocking proposal of the low-cost EVM consists of the VCXO chip PI6CX100-27W, the PLL chip PLL1705, several bus drivers, and a few oscillaors and crystals. This application report discusses several optimized clocking proposals with the Texas Instruments new clock drivers and recommends a m
Серия: CDC906 (4)
  • Semiconductors > Clock and Timing > Clock Generators > General Purpose
На английском языке: Datasheet Texas Instruments CDC906PW
